IS350 OEM wheel stud length?
I've running some iForge that has a bit of a conservative offset. I am just adding a 5MM spacer but with the spacers I can only get 2 1/2 turns on the lug. I know that Ichiba makes wheel studs for the Is350 but the longest they have is 50MM which is ~ 2". As Javier said, 2" is the stock length. Is there any other place that sells longer studs than 2"?
markdav801 (01-14-18)
Tech Info Resource
The stud is 12mm x 1.25mm x 36.5mm.
Tech Info Resource
If you like your hubs, don't use a hammer. It will dent the ***** in the wheel bearings. Use a C-clamp with a socket and press them out. OTC makes a wheel stud press that's basically a C-clamp style tool with a forked end so the stud will clear the clamp when it's pressed out. The part number is 09650-17011. OTC also sells a full kit.
Just curious about the rear studs... Is there enough room behind to press out without removing the axle? I'd think so, but looking at this thread:
http://my.is/forums/f89/brake-pad-ro...tached-255699/
I'm worried. Anyone know? Thanks!
Whoops, wrong IS - I'm working with the IS300
Because 36.5mm doesn't equal 1.75" as what javy's pic shows.
*Edit, I realize this is an old thread. But valuable info is in this thread.
*Edit 2... I see it is indeed measured from the first thread to the last thread.
