By Request: Aftermarket Auto Shifter
Old Feb 23, 2009 | 01:43 PM
2.5tsoarer's Avatar
2.5tsoarer
Default By Request: Aftermarket Auto Shifter
I've been ask how I did this quite a bit so I decided to do somewhat of a how too.
This was done years ago so I don't have pictures during the process but hope this helps.
Tools Used:
Dremel
Angle Grider
Wire Cutter
Drill and Taps
Parts Used:
Shifter $10 on auction site
5 Spd shifter bezel and boot from Luxurymods
I don't have the info on how to remove everything but there is no doubt it is on this site somewhere.
Once the bezel and shifter is removed, you most remove the OD wires and mount a shift somewhere else.
Then grid the area shown to reduce the diameter of the shaft in order to fit the new shifter.
Once the shifter has been test fitted, you will have to discard the plastic that sat under the bezel to allow the 5spd SC shifter bezel/Boot to sit correctly.
drill the 2 holes on the new shifter to allow use of the OEM set screw holes
Here is a picture of the shifter before installing.
I did have to drop in a Nut as a gap filler inside the shifter in order for the push-down to work.
I purchased the shifter on an auction site, but will not provide that info due to Forum rules.
Old Feb 23, 2009 | 01:58 PM
TheMole's Avatar
TheMole
Pretty cool. Hopefully this will give an answer for all those who were wondering.
Old Feb 23, 2009 | 02:24 PM
kohlex's Avatar
kohlex
wow that looks amazing, great job! and thanks for the DIY. Is this a specific type of **** for AT? or is it a MT **** adapted to fit? Thanks
Old Feb 23, 2009 | 02:27 PM
2.5tsoarer's Avatar
2.5tsoarer
if you goto an auction site and search automatic carbon fiber shift **** you will find the one I used.
Old Feb 23, 2009 | 02:53 PM
JDMfoLIFE's Avatar
JDMfoLIFE
Thats pretty dope!! And it give a clean look!
Old Feb 23, 2009 | 03:03 PM
kwheels's Avatar
kwheels
does yours have a button, or do you just push the whole shifter in place of the button?
Old Feb 23, 2009 | 03:20 PM
2.5tsoarer's Avatar
2.5tsoarer
the whole shifter, here is a video
http://www.youtube.com/watch?v=XYPs1Pp0h58
Old Feb 23, 2009 | 03:42 PM
drft_n_sc's Avatar
drft_n_sc
what is that digital display where the seat warmer switch once was for??
Old Feb 23, 2009 | 04:22 PM
ThomasGS4's Avatar
ThomasGS4
that's the bad *** supra stick! and that's not where the seat warmers are/were
Old Feb 23, 2009 | 07:07 PM
Matador's Avatar
Matador
I feel like Ive seen the auto supra guys do something similar, it came out REALLY good. Did you relocate the PWR button?
Old Feb 23, 2009 | 08:07 PM
projekt's Avatar
projekt
where can u get an shifter **** for the sc400 for $10? i would like to know.
Old Feb 23, 2009 | 08:16 PM
durtysc300's Avatar
durtysc300
i guess no more OD anymore right? haha
Old Feb 23, 2009 | 09:57 PM
Hil's Avatar
Hil
That's pretty awesome. Nice work!
Old Feb 23, 2009 | 10:04 PM
soarinhigh's Avatar
soarinhigh
This is a great mod. If i had an auto I would do this for sure.
Old Feb 23, 2009 | 11:27 PM
LuxuryMods's Avatar
LuxuryMods
Former Sponsor
Very nice writeup, one of my fav's here on CL.
Did I read somewhere that you were selling your beast?
