I just recently purchased an 06. I was looking at the third row seat and noticed there was a place to attach a middle headrest. I figured that I would have to buy one if I wanted one. Then I happened to upzip the zipper running across the back of one of the third row seats. It turns out that the middle headrest is stored inside that seat. Pretty slick.
That made me think that there might be other hidden compartments, etc. that I don't know about.
Has anyone else found any type of "hidden" features with their GX?
The only other hidden compartment I can think of is where the wheel lock adapter is. It was like finding a hidden treasure when I finally found it. It's in a little black leather pouch attatched to the tire jack.
The sales person I dealt with wasn't very informtive on the GX, I have learned a lot reading the owners manual, as well as reading older threads in here. I believe I knew more about the truck than he did! Like, the sun visors flipping over to the side windows, and then pulling out, and the second sun visor that folds down when the primary one is flipped to the side. Also, the ignition is electronic, and doesn't need to be held to start the vehicle. There is also the trick to override the navigation system, and the self dipping side mirrors as long as the adjuster switch is left to the L or R position, but overriden in the neutral position.
On the Passenger Side Glove Compartment Door frame (ie Once opened) there is a s/w to adjust the TPMS warning if at all you get on the cluster. The s/w is identfied as Main(Up) and 2nd(Down). The s/w when on Main is for normal and for Snow ride you have to move to done position. If at there is a warning when you have the tyres changed, you need to toggle this s/w so that the ECU reads the new values of the Five wheels sensors.
Nope. Just tap it and the car does the rest. It's the coolest feature imo.
There is a slight resistance to take the key to the "start" position (almost like a spring action) and the car starts. is this what you mean by "just tap it". I don't need to hold the key at the start position.
Yes...
Have you never owned any other cars? All my other vehicles require me to hold the key in the "start" position until the engine fires up... if I let go early the car will not "ignite". (normal car: Twist right, hold until starter makes engine fire, release... Lexus: Twist right, let go immediately to do other things, car does the rest)
I'm not sure what you guys don't get lol. Try twisting your hand clockwise real quick and let go. Your lexus will start.
Try this in another car and it will crank for a fraction of a second and nothing with happen.
