SC- 1st Gen (1992-2000)
Sunroof install help please
Old 01-03-09, 02:33 PM
jgscott
jgscott's Avatar
Received 1,260 Likes on 1,000 Posts
Default Sunroof install help please
Ok I've got a Sunroof out of a very, very low miles 2000 SC400. I want to install it in my 1999 SC400. It came with the complete plastic bed that it sits in containing the rail tracks and everything.
Couple of questions.
1. Can you just replace the glass w/o intalling the whole thing ?
2. My car is Black interior, and this one was tan, so the trim and inside cover are different colors. Can they be changed out or is this one complete unit that cannot be broken down ?
3. Does anyone have a pic of the diagram breakdown they can post.
4. How do you install it ? I searched and found nothing.
Thanks
Old 01-03-09, 04:49 PM
felixsc300
felixsc300's Avatar
Does the SC in question have an opening on the roof to install the moonroof?
Old 01-03-09, 05:41 PM
CCC-TT
CCC-TT's Avatar
^ +1, and if so, whats wrong with your current one?
Old 01-03-09, 05:44 PM
jgscott
jgscott's Avatar
LOL ! Yes I'm trying to replace just the glass because it's starting to get a little wind noise, and the glass rubber trim is not replaceable.
What I'm tring to find out is how you take it apart to just get to the glass.
Old 01-04-09, 01:23 PM
Hil
Hil's Avatar
Yes you can remove the glass only. I did it just now
-Get into your car and look up at the sunroof
-Notice the plastic trim that runs around the glass. (these should be tan for you)
-The end pieces that run parallel to the door are removable.
-Use a flat head screwdriver and pop those 2 pieces out to reveal 3 bolts on each side
-Remove all six, push up lightly on the glass and it should be removed
Old 01-04-09, 06:07 PM
jgscott
jgscott's Avatar
Thanks, I was dreading this job. I tryed to pry off the front plastic trim and it was a no go, and about to break. I thought you had to take off the entire side peices near the side windows and headliner.
For anyone who has a wind noisey sunroof :
I took some black duct tape. Folded it in half suck it to itself and then wegeded it up in the rubber sunroof glass seal as far as I could get it. I then cut off the tape that was hanging down from end to end. Put some silicone on the rubber and closed the roof a few times. This dramatically reduced the wind noise by 75 - 80 % better !
But I still wanted it completely quite. So a searched the web and found a used Sunroof from a 2000 SC with only 27k miles at a used parts place. They sold it to me for $ 50. That's why I'm replacing my old Glass roof. Problem was they sent me the whole sunroof assy. . Guess thats good tho cause I have every spare sunroof part, motor, tracks, shade cover and so on.
Old 01-04-09, 09:13 PM
ThomasGS4
ThomasGS4's Avatar
woah a 2000 sc with 27k??????????
Old 01-05-09, 04:59 PM
CrazySC300
CrazySC300's Avatar
Originally Posted by jgscott
"...I'm trying to replace just the glass because it's starting to get a little wind noise..."
There's a remedy for that, get a moonroof visor.
Old 01-05-09, 06:03 PM
jgscott
jgscott's Avatar
I hate those things. They mess up the SC's lines.
Ezroni (02-18-22)
Old 01-06-09, 08:36 AM
kyoso23
kyoso23's Avatar
Plus they warp and end up making twice as much noise after awhile, plus the paint damage they cause.
Ezroni (02-18-22)
Old 01-09-09, 06:08 PM
NSeagle78
NSeagle78's Avatar
Do u still know the web address of the place u got the glass from.
Old 01-10-09, 04:44 PM
jgscott
jgscott's Avatar
www.car-parts.com
Sportskid1
10-24-20 10:59 AM
falconer
Hybrid Technology
11-21-13 03:28 PM
Track5tar
10-27-10 05:34 PM
dale88
03-13-06 11:23 PM
lexus_mark
RX - 1st Gen (1999-2003)
03-24-03 05:15 PM
Quick Reply: Sunroof install help please
