LS460 Wind Noise Fix (continued discussion)
Do you still have some swishing wind sound after this fix?
I just cut and pasted this to my dealer.....Great documentation!!!!!!
JMCraney; I think your post is a great show of ingenuity, something the Japanese may be lacking in their pursuit to perfection. Posts like yours is what makes these kind of boards so great to me and I'm sure others....well done.
Had the TSB done Oct 2007. Came back with worse noise. Sent it back and also complained about the black triangles not being fitted well at all. Came back second time much quieter and my triangles well fitted.
Did the spring wash and wax yesterday and noticed the triangles had worked their way out of position. Was thinking to myself that I just need to pull them off and fix them right - and wondering how they were attached. Finished waxing, went inside, and read jmcarney's triangle posts for the first time.
If the triangles are part of the problem, I wonder if they might work their way out of position, which could partially explain those cars which develop wind noise after a few thousand miles.
Anyway, thanks for the pictures jmcraney!
Bob
Bob
In my case, the large gaps that are under the rear corners (I am talking about both sides of the car) seem to be the real problem. It is possible that other cars do not have these large gaps or they may be closed with something. On my car the plastic triangle trim seemed to be firmly placed with mounting tape. But, as you can see from my picture – the one with the red text on it - that the mounting tape did not adhere along the bottom as evidenced by the tear-off-residue. If the adhesion of the mounting tape had been adequate, then the problem might have been much less severe.
As for what causes the noises: I don’t know if the wind currents cause an over-pressure or under-pressure but lots of things could happen. Air could be entering or exiting in this area, depending on the pressure, and could be amplified by liftoff of the trim if the pressure is low. The plastic triangle trim could act like a reed and produce some odd sounds. Or wind blowing over those gaps at the corners could produce sound kind of like blowing on a jug. Another possibility is that the trim piece could vibrate like a drumhead and cause some strange sounds. This sort of speculation is kind of like “stompin **** ants while the elephants are in the corn” because the cause is not really important anymore.
A competent engineer with some time to ponder this problem can probably come up with a more elegant solution. My approach takes about 10 minutes to do both sides and cost about $1 in materials. The only concern I have with my solution is that the sealant might not adhere well to the plastic or chrome but for now everything is much better. I will let you know if I loose my trim to the wind. For now, a Noiseless/Trimless Lexus might be better than a Noisy/Trimmed Lexus.
In the cases where this problem manifest itself over time, that may be cases where the mounting tape has let go. Another possibility is that the tape lets go because of the strong wind currents in that area.
If your plastic trim piece is moving around, I think you should be concerned about that.
I'm wondering if some good 3M double-sided tape placed completely around the perimeter of the trim piece wouldn't get the job done ... and would be more easily reversible if anyone wanted/needed to take the trim off again.
Just a thought. But in the meantime, I imagine the silicone will be there for the duration. It sticks to most anything.
