lexus is 250/350 smart keys
Old 03-28-08, 06:46 PM
is350power
is350power's Avatar
Default lexus is 250/350 smart keys
just wondering if anyone here have changed there smart key battery. yet?
if so did you guys have to get the smart key to the dealer for them to program the smart key ,,,again??
Old 03-28-08, 06:53 PM
XprincoX
XprincoX's Avatar
yeah u need to take the new key to the dealer to have it programmed to your car.
Old 03-28-08, 07:20 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
edit: oops.....
you should be able to use it after you put in the new batt......
Old 03-28-08, 08:08 PM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
Huh?!?!? You don't need to reprogram anything after changing the key fob battery.
Old 03-29-08, 06:41 AM
greg0723
greg0723's Avatar
i was told the battery lasts a long time?
Old 03-29-08, 08:16 AM
Joeb427
Joeb427's Avatar
I change my batteries in my vehicles key fobs every two years and never had to have them reprogramed.
Changed the IS batteries a few weeks ago.
I usually buy hard to find number batteries on Ebay.
Old 03-29-08, 08:55 AM
IS350jet
IS350jet's Avatar
You're right, but if the battery is removed for an extended period of time, or it remains dead for a while it will have to be re-programmed. I'm not sure what that time is, though. I think the owners manual explains it.
Old 03-29-08, 10:33 AM
Brian231
Brian231's Avatar
The FOB batteries are only about $3 a piece. They are the "CR" type and need no reprogramming. You will be fine.
Old 03-29-08, 10:58 AM
ExTrEmE99
ExTrEmE99's Avatar
I think next time i order from sewell i will stock up on some batterys and store them in the car. I got a quick question:
When the fob dies, i know you have to use the metal key to get into the car but i cant turn the metal key in the hole under the door. ANY special trick?
Old 03-29-08, 11:04 AM
Brian231
Brian231's Avatar
Might be a little corrosion in the lock mechanism. Just my guess, let the dealer check it out on your next service. Possible salt air living in SF with the Pacific nearby. Maybe spray a little WD 40. You can purchase those CR batteries at Radio Shack, Wal-Mart, Target etc. Save money not buying it from the dealer.
Old 03-29-08, 11:06 AM
LexusIS-TL
LexusIS-TL's Avatar
How much do Lexus dealerships charge for battery replacement for the FOB?
Old 03-29-08, 11:26 AM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
My dealer changed mine for free as a courtesy. People on the forum have reported paying as much as $12 at their dealer. They are available for a fraction of that on eBay.
Old 03-29-08, 11:31 AM
LexusIS-TL
LexusIS-TL's Avatar
Would you happen to know the exact battery number or model number to get? NVM, found it:
CR1616
Old 03-29-08, 11:33 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
the fob uses CR1632, not easy to find at regular stores.....
Just order them from ebay, avg cost ~$2......
Old 03-29-08, 11:40 AM
LexusIS-TL
LexusIS-TL's Avatar
The Energizer version has the "E" in front of it as shown here:
http://cgi.ebay.com/Energizer-cr1632...QQcmdZViewItem
It's the same right? They have it labeled as "ECR1632" on the package.
At this rate, we should change our batteries every year.
Quick Reply: lexus is 250/350 smart keys
