How To: Build and Hardwire an Auxillary Input to OEM Stereo
And have to build something for the cup holder to mount my sirius Sportster 4 :-P
will keep everyone posted
i havent got the relays intalled cos I wanna test how it works first. one more thing is that my CD changer stops working already. so my work is as simple as cutting the wires and connecting the iPod. Will think of installing the replays when i install my car computer. doing so i will have 2 sources of input (ipod and car pc)
One important note for '90 LS400 users, there are 4 wires at the back of the head unit with exactly the same color as CDR+ CDR- CDL+ and CDL- (violet, light green, blue and pink) but they serve the 2 front speakers. I cut them and ended up having no sound from my 2 front speakers. the correct wires with the same color need to be cut have the BLUE connector, while the WHITE connector is not some thing you should cut. please refer to the wiring diagram i posted earlier for more information
regarding the re-print of buttons, i am thinking of using a sticker (or sticky label) that people use for computer asset labeling. black sticker printed with white letter should give an OEM look. i havent tried that anyway
Another problem I see after I've pulled everything up. It doesn't look like I have a damn amp! What do I do now? I know it is suppose to be either under the passenger seat or under/over the CD changer in the trunk. No luck in either spot. I have a 94 LS400 with a Pioneer Changer in the trunk that actually has a 93 manufacturer sticker on it. The changer looks nothing like the one in this link:
http://www.carstereohelp.com/stereor...400CDChgrR.htm
It has the same black housing, but the changer itself is sunk down deeper in the housing/shell and looks like this:
http://carstereohelp.com/lexus.htm (scroll down to CDX-M8036zt, actually that same model number is on mine, but the changer says Pioneer...don't ask me)
NO OTHER WIRES anywhere else around the changer besides the two blue connectors connected to the changer. Those lead somewhere back into the car.
As far as under the passenger seat goes, My vent looks NOTHING like the pic at the beginning. There are no screw or screw covers, the vent itself looks nothing like the one in the pic, and the carpet covers all the way through the floor except for a slot for the vent that is there, and a slot for some wires rising out of the floor, which I assume is the cars computer or some other type of wiring.
So where is my amp...or does my car not have an amp like everyone else'? ....odd I would think. If I don't have an amp, what do I do now?
please note that The vehicle i installed into for the DIY was a 2000 LS400, which has wiring that is completely different from the 1st gen cars.
i will say this once, ALL FIRST GEN LS400s HAVE AMPS.
please search in the LS400 forum (please dont just create a thread to ask)
p.s.
if you search for the word "amp" on this forum you will not get any results, type "amp*" into the search box for the LS400 forum (without the quotes but with the *) and results will start turning up.
I do have a problem however. Hopefully someone has come across this. When I have my device switched on, AND it is plugged in the cigarette lighter for power, I get a buzzing sound. NOTE: it is not plugged in directly, it is plugged in through an AC/DC converter. And I do not get the buzz when it is not plugged in.
1/ Is it because of the converter?
2/ Will it make the sound if I get a standard car adapter...if there is one for me?
3/ If I put a suppressor between my device and the headunit will it get rid of the buzz?
Any help please.
Thanks...and great tutorial.
Good luck!
