1.) I need to use the supra throttle cable because the throttle body on the gte is different that on the ge correct?
2.) Is there any way to use the ge clutch fan and waterpump on the gte?
#1 You are correct. Make sure you order it for Turbo model
#2. You can not use the GE clutch and fan assembly. The fan will hit the top water neck. You can use a TT Supra fan assembly, or can use electric fans. Buy a new water pump from Toyota-be sure to get the front half and back half. I paid $130.
Ok, that straightens things out. I replaced the water pump on the gs recently and thought I might be able to get away with using it, but I guess not. Would you guys recommend to just get an oem supra radiator or to step up to an aluminum one? I am thinking of going bpu right away and upgrading some things, so I'm wondering if there will be any benefit there.
If going electric fans, yes upgrade the radiator. I have a Griffin radiator and I ran a little bit hotter than I liked when the temp was over 105 ambient. I'm going to relocate my trans cooler from the condenser and I think that should cool it down enough.
I have a tt clutch and fan sitting in my garage I'm not using. I was going to put it on but never got around to it. I would have had to rearrange my intercooler pipes. Let me know if you need it.
hey guys i have a couple questions here for u. i bought a 1g aristo front clip and have torn it apart already. while i was refreshing the motor i ran in to a problem the water pump i ordered would not match up with the water line on the block. bolted right to the block but was about a inch short of the water line then i also noticed that its thermostat housing bolts were in a different angle and the upper pipe didn't have the pipe of the water pump going to it. so what should i do. otherwise the project is going smoothly so far. ill get some picks up this week if i get a chance. also if any of u are local that have done this swap that would be awesome.
for what i no the water pump i orderd is a 93 supra tt
But with Aristo 2JZ engines being so abundant, they are the logical choice. I will probably swap a VVTi 2JZ into my '93 GS300, but that's just because I like being difficult
R7 is a resistor and you need to jump from one side to the other. It's just above the orange plug. I just reinstalled my US tach and jumped it. It is the solution!
I just did this and took pictures so everyone could see how to do it. It was very very easy and took about 20 minutes.
Here is a close up. I used a little zip tie to keep it tight after twisting the wire on with a set of small needle nose pliers..........then but it back in and your good to go. RPM gauge works perfect............
I have a 1994 GS 300. I want to put the 2JZ-GTE in it. I want to know everything that I need to know to make this happen. Can someone tell me how much money Im going to need and exactly what parts im going to have to buy. Thanks
