The First Gen Power Steering Bible
The only thing we're lacking is info on how to actually remove the pump, and possibly the high pressure hose. It would be great if those who have replaced these items themselves would post instructions or tips. Those 4 bolts seem impossible to reach!
Tips for cleaning the solenoid: brake cleaner combined with a toothbrush (preferably your roommate's)...comes clean really quick.
Its the O-rings that go bad just like the O-rings on the pump and reservoir.
cap it with the bolt I was talking about and cap the lines and you'll be good.
It is easier to change it from the bottom with a wrench. Some say from the top. I say bottom, whatever. Suck out the fluid first or be ready to catch some of it when you do remove it.
I have had a chat with a really good mechanic lately and he doesn't even bother capping. He buys a rebuild gasket kit for the pump, changes a few O-rings and the small o-rings on the valve and puts it all back together.
might be an avenue for us all to look at.
I had to replace my PS pump in 2001, my 1991 LS has 112K miles on it.. It ruined the alternator.. I had the dealer replace and it was like $850 back then. But it works great.. ANd my new alt is still clean.....
I wonder if the LS has higher pressure causing these pumps to fail, I mean as easy as the wheel is to turn, I wonder if that is the cause for problems/?? I wish they would use the old PS pumps that were metal they have on vans/trucks, those never go bad....
These plastic saginal pumps just seem to last a little over 100k and they start leaking..
Also my rack leaks a little bit.. I add a little fluid about once a year...Also my high pressure hose is a little wet... maybe the next pump That stuff will get replaced..LOL..
Good info.
