OH FS: ISx50 " X " Package Sport Suspension setup- $275 shipped!
Old 08-24-11, 08:56 AM
mikellucci
mikellucci's Avatar
Default SOLD: ISx50 " X " Package Sport Suspension setup- SOLD
SOLD, thanks!
I recently purchased these from another forum member but have since installed coilovers and never used these. They look to be in great shape with 18,000 miles.
Moderately lowers your IS and sport tunes the ride. Lowers the front .4" and the rear 0". Complete Assembly for easy install.
Lexus IS250/350 X Package Sport Suspension - $275 shipped
EXCERPTS FROM A REVIEW at EDMUNDS.COM
"X" Marks the Spot
Sport packages are all too often more about style than substance, so we didn't expect the addition of the X Package to assure instant handling credibility for the IS 250. Sure, you get 225/40YR18 tires in front and dramatically wider 255/40YR18s in the rear, plus a firmer suspension setup, but lighted door-sill plates aren't going to give you more grip in the corners.
Surprisingly, the sport package doesn't degrade the IS 250's ride quality, which is the essence of what Lexus is about, after all. On the street, the IS 250 remains forgiving over most surfaces.
And once you toss the IS 250 into a fast corner, the sport package really shows you something. The car settles quickly on its suspension into an effective cornering attitude and the stiff-sidewall tires help the steering react to subtle inputs more responsively than you'll find in an all-wheel-drive IS 350.
In tight-radius corners, the bumps that momentarily upset the IS 350 barely faze this buttoned-down IS 250. Given that the rear-wheel-drive, 3,527-pound IS 350 and rear-wheel-drive, 3,455-pound IS 250 have the same weight distribution of 52 percent front/48 percent rear, we're surprised the IS 250 feels so different.
Slalom Superstar
The X Package improvements also translate to the track, as our slalom test confirms. Although it's down over 100 hp on the IS 350, the IS 250 is nearly 4 mph faster through the cones with a 70.4-mph result. This is blazing speed, and it puts the IS 250 ahead of the BMW 335i, not to mention about a half dozen very capable sports cars.
The rear-wheel-drive IS 250's overall grip on the skid pad is a fraction less than that of the rear-wheel-drive IS 350, as the IS 250 manages 0.84g versus the 0.87g we recorded for an IS 350 with 18-inch wheels and tires. The two cars are also about the same in braking performance, with the IS 250 posting the shortest stop from 60 mph at 113 feet.
And we discovered that the extra margin of driver command afforded by disabling the IS 250's stability control system doesn't translate into performance you can measure, as Lexus already has the electronics dialed in quite precisely. But we still appreciate the choice.
SOLD, thanks!
mikellucci is offline
Old 08-25-11, 03:26 AM
felixsc300
felixsc300's Avatar
Interested - how much does this lower in comparison the standard ride height?
felixsc300 is offline
Old 08-25-11, 07:22 AM
mikellucci
mikellucci's Avatar
Old 08-26-11, 08:34 AM
mikellucci
mikellucci's Avatar
bump.. these are better then stock!
Old 08-27-11, 06:46 PM
mikellucci
mikellucci's Avatar
Need these gone!
Old 08-28-11, 06:13 PM
timgs300
timgs300's Avatar
Will vouch for Mike. These make a huge difference! You'll look smokin' hot and handle the corners with flattitude
timgs300 is offline
Old 09-04-11, 05:07 AM
mikellucci
mikellucci's Avatar
^thanks man!
Old 09-04-11, 01:16 PM
Sango
Sango's Avatar
Might want to clairfy and update the title that what you have is for the 350 back from your other post.
Originally Posted by mikellucci
Def works! I have a set of the f/r X-package springs/tophats from the is350. (they are posted in the classifieds)
It cannot be both because of what was mentioned from Jeff.
Originally Posted by Jeff Lange
2006-2010 Sport/X-Package/F-Sport Package:
48510-80257 - RF Shock
48520-59285 - LF Shock
48530-80289 - Rear Shock (Qty: 2)
48131-53151 - Front Spring (IS250, Qty: 2)
48131-53171 - Front Spring (IS350, Qty: 2)
48231-53151 - Rear Spring (Qty: 2)
Sango is offline
Old 09-05-11, 07:01 AM
funglenn
funglenn's Avatar
will these fit an awd 250?
funglenn is offline
Old 09-05-11, 03:27 PM
mikellucci
mikellucci's Avatar
When I search the following part numbers it comes back for both the is250 and is350!
48520-53030
48510-53010
48530-53100
48530-53100
Is350:
http://is.sewellparts.com/oem-catalo...S350-2010.html
Is250:
http://is.sewellparts.com/oem-catalo...S250-2009.html
Old 09-05-11, 08:01 PM
Sango
Sango's Avatar
Oh opps my bad. Hmm I didn't check them against Sewell, I assumed Jeff lol!!
Thanks for the clarification.
Sango is offline
Old 09-06-11, 01:29 AM
Sango
Sango's Avatar
Actually I correct myself. The absorbers do match, however it's the springs which don't, that's why I was saying you might want to clarify which which these are for. I double checked on Sewell.
48131-53151 - Front Spring (IS250)
48131-53171 - Front Spring (IS350)
Sango is offline
Old 09-11-11, 11:46 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
PM Sent.
Jeff
Jeff Lange is offline
Old 09-12-11, 11:36 AM
itruns
itruns's Avatar
Are these just the springs or shocks as well? And are they for a is350?
itruns is offline
Old 09-12-11, 12:14 PM
mikellucci
mikellucci's Avatar
They were the complete package (see p/n s). They are sold and shipped. Thanks!
Quick Reply: OH FS: ISx50 " X " Package Sport Suspension setup- $275 shipped!
