ID Complete AIR kit. UAS bags, Bilstein struts, Dakota Gauge & More! 9 way adjustable
SALE IS ON HOLD UNTIL THE LAST PUMP COMES BACK FROM VIAIR. FEEL FREE TO STILL PM WITH QUESTIONS.
Complete bag kit. UAS bags, Bilstein struts, Dakota Gauge & More! 9 way adjustable switch box
I have decided to return the car back to stock in order to sell it. I am not interested in parting out this air kit. Only looking to sell it as a complete kit with all the stuff listed here.
This is my first car with air ride on it, and I purchased it with it on the car so I am a noob when it comes to air ride. I believe I have everything listed correctly but if not feel free to let me know so I can change it!
• 4 UAS Bags on Bilstein Struts w/ lines and fittings from each strut up into the trunk of the car. One bag was starting to wear a smidge so I sent it into UAS and its BRAND NEW now. ALso included are some extra "protection" that I put around the line where it made contact with the body to prevent it rubbing through and creating a hole.
• Dakota Digital PSI gauge installed NICELY in the ash tray. The tray is included.
• 9 way adjustable switch box. This lets you control the cars height pretty much anyway you want from each wheel individually, to the entire car at once, and everywhere in between.
• 2 tanks with braided lines going to the pumps. Both have a check valve in them. One tank has the PSI gauge on it, the other has what I believe is the pressure switch...That shuts the pumps off at a certain PSI. Both have drain plugs at the bottom of each tank.
• 2 polished Viair 480c pumps. One of their nicer pumps. BRAND NEW rebuild with zero hours on them straight from Viair themselves.
• 80ft of airhose. 50ft of it is brand new, never been used. The other has been used. Has all of the fittings and connectors you need.
• All the wires to run front/back of car. Everything you see in the picture is included. The wires coming from the valves are labeled so when you run them up front you know where to connect them with ease. Though a few of them would be good to run all new wire some were barrrrrrely long enough to reach where the box is mounted (under the passenger side dash) so if you mount it anywhere else you will need to lengthen the wires.
• All of the switches/valves mounted on the custom board that fits nicely in the back of the GS trunk. Its cut to fit almost perfectly!
Any questions feel free to ask. $2100 shipped for everything.
Here is my car not slammed on the ground..but slammed as far down as I can do and still safely drive w/o hitting everything on the road! It goes lower and rests the bottom of the car on the ground.
Forum Administrator
Originally Posted by LexusFTW
I can vouch for TheMadGS3.
I've dealt with him on Supraforums where he is a respected and honest member.
New Product Air Rex Air Struts and Bags Kit For Lexus LC
RavSpec
CL Vendor Products for LC
10-11-17 09:41 AM
RavSpec
CL Vendor Products for GS-F
10-11-17 09:38 AM
RavSpec
CL Vendor Products for RC-F
10-11-17 09:19 AM
RavSpec
1Gen RC350 / RC-F Classifieds
10-11-17 09:09 AM
