Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
headlight restoration with 1500, 2000, PLastX
Old Jun 2, 2007 | 07:34 PM
MrG4Life's Avatar
MrG4Life
CL Folding 100,000
What a difference
Old Jun 2, 2007 | 10:27 PM
Lexizm's Avatar
Lexizm
Great results man !!! I'm going to try this one; I'm afraid of using the orbital buffer though. I don't want to sand it unevenly and mess up. I think I'm going to do it by hand first.
Old Jun 2, 2007 | 10:35 PM
chrispy's Avatar
chrispy
Try some 3M rubbing compound after the 2000 grit. I'm sure the buffer will help a lot more though.
Old Jun 2, 2007 | 10:56 PM
GSteg's Avatar
GSteg
As long as you dont stay in one spot for long, you shouldn't have a problem. If you have a random orbital buffer, then you have almost no chance of ruining the plastic. Using 2000 grit sand paper takes out a very thin layer of the plastic lens. Just go side to side. No circular motions allowed!
Old Jun 3, 2007 | 05:13 PM
GUNRU-GS4's Avatar
GUNRU-GS4
Wow, thats a great improvement
Old Jun 3, 2007 | 09:52 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Are you talking about using the Orbital buffer to sand? If so thats a big NO NO. Use the orbital buffer to polish and just go in swirling motions all along the lense.
Old Jun 3, 2007 | 09:59 PM
GSteg's Avatar
GSteg
I just realized he probably meant using the orbital to sand.
Lexizm, do not use the orbital buffer to sand !!!
Old Jun 4, 2007 | 03:06 PM
PushinLEX's Avatar
PushinLEX
Incredible results!!!!
I agree with whomever said to use rubbing compound between the 2000 grit and plastix. After plastix, I would use plastic polish then finalize w/ a coat of wax.
Old Jun 4, 2007 | 08:32 PM
Lexizm's Avatar
Lexizm
Thanks guys, I'm goig to do this in a couple weeks. Don't worry sanding by hand, I would have confirmed before I touched the lens.
Old Jun 6, 2007 | 09:17 AM
URDONE's Avatar
URDONE
Very well done.
Old Jun 6, 2007 | 11:40 AM
HighSoarer's Avatar
HighSoarer
The turnout looks great. I just recently did the same with my SC400 headlights. I took a long time wet sanding to make sure everything was as smooth as possible (about 30 minutes per lense) because I'm a little **** about it. Then I used a rubbing compound before using the polishing compound. It came out rather nicely minus a streak or two on my drivers headlight (with the polish you can only apply in one direction and I accidently polished both ways on one lense). It all came in a headlight restoration kit I bought the other day at Advanced Auto for about $20. My lamps look brand new now. Now if I can just get this last clip to my passenger headlight so I can finish taking it out to seal up the moisture with some silicon gel I'll be good to go for the day.
Old Jun 15, 2007 | 01:23 PM
Chenzo26's Avatar
Chenzo26
Anyone know where to get 1500 and 2000 grit sandpaper? I went to lows and the finest they got there is 600.
Old Jun 15, 2007 | 01:29 PM
chrispy's Avatar
chrispy
Any autozone or pepboys should carry high grit wetsanding paper.
Old Jun 15, 2007 | 01:59 PM
GS300Rich's Avatar
GS300Rich
that is a huge difference, great job
Old Jun 27, 2007 | 10:10 PM
LexFather
Guest
Posts: n/a
Stuck, tons of Lexus owners ask about yellowing or dirty headlights...gonna merge some threads...
