Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
headlight restoration with 1500, 2000, PLastX
Old Jun 1, 2007 | 05:31 PM
jpcdmd's Avatar
jpcdmd
Default headlight restoration with 1500, 2000, PLastX
The headlights on my 01 LS430 had several pits and scratches from the sandy desert of Arizona. I wet sanded them with 1500 grit sandpaper, followed by 2000 grit sandpaper, and then PLastX from Meguiar's. While this worked well, I still notice very slight haziness, not perfect clarity. They are definitely much much smoother from the sanding though.
I feel like there should be a step for some product in between the 2000 grit and the PLastX, in order to achieve a completely clear result. Or maybe something to use after the PlastX?
I'm tempted to try the Wolfgang Plastic Lens Cleaner kit or the one from Lake Country, but can't bring myself to spend the $50 if it won't make that much of a difference.
Here's a few before shots:
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1723.jpg
Old Jun 1, 2007 | 05:32 PM
jpcdmd's Avatar
jpcdmd
another angle
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1725.jpg
Old Jun 1, 2007 | 05:33 PM
jpcdmd's Avatar
jpcdmd
polishing with the sandpaper
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1726.jpg
Old Jun 1, 2007 | 05:34 PM
jpcdmd's Avatar
jpcdmd
and the 2000
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1727.jpg
Old Jun 1, 2007 | 05:35 PM
jpcdmd's Avatar
jpcdmd
after using the 2000, the lens looks very hazy. All the pits and roughness are gone though, its very smooth. Although it looks like I was sanding dry in the photos, I actually used a lot of water.
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1729.jpg
Old Jun 1, 2007 | 05:36 PM
jpcdmd's Avatar
jpcdmd
followed up with the PlastX
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1730.jpg
Old Jun 1, 2007 | 05:37 PM
jpcdmd's Avatar
jpcdmd
the bottle
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1731.jpg
Old Jun 1, 2007 | 05:38 PM
jpcdmd's Avatar
jpcdmd
finished product
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1732.jpg
Old Jun 1, 2007 | 05:39 PM
jpcdmd's Avatar
jpcdmd
another angle
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1733.jpg
Old Jun 1, 2007 | 05:40 PM
jpcdmd's Avatar
jpcdmd
another angle, you can still make out some very light scratches but they look better overall.
Attached Thumbnails headlight restoration with 1500, 2000, PLastX-img_1734.jpg
Old Jun 1, 2007 | 05:47 PM
jpcdmd's Avatar
jpcdmd
anyone use this product before? how does it compare to the Wolfgang kit?
http://www.superiorcarcare.net/plast...on-system.html
Old Jun 1, 2007 | 05:49 PM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
wow great job they look awsome
Old Jun 1, 2007 | 06:04 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Next time hook a pad up to an orbital buffer and try that out. You should get a clearer result for the polishing aspect of it.
Old Jun 1, 2007 | 10:41 PM
GSteg's Avatar
GSteg
I agree. If you want top notch work, use a buffer. My friend did his car. It went from the nastiest looking headlight (5x worse than yours) to OEM clear lens. You'd think he bought new headlights. It's that good
Old Jun 2, 2007 | 07:20 PM
jpcdmd's Avatar
jpcdmd
I just tried it with my PC and a white pad, no difference. Go figure.
