Screwed with touch up paint!
. We thought we could really just clean the affected area(s) with rubbing alcohol and touch up the area with the OEM paint provided (this was before I got the Gx470 and joined CL). Boy were we wrong. What can do to make the area look decent??
General misconception with touch up is that you can just dab it on and forget it. You'll need to wetsand to evenly match the paint and then buff out the fine scratches with a polish (like 3M rubbing compound, meguiars DACP, etc). But you'll have to clean up the surface first (wash area, and then claybar if possible)Then you put on a layer of wax to make it pretty
. Here is an example of my car. It has two long/deep scratches on the fender.:
Applying touch up paint. (basically what you did so far)
After wetsanding with 1000 grit and then moving onto 2000 grit:
Final result after polishing:
My paint is just black without any metallic or goodies, so repairing it was easy.
The hardes thing about this job is color matching. But since my black onyx doesn't have sparkle in it, the hardest thing was paint leveling. It's just takes a lot of patience, but it was worth it considering you could see my two 7" scratches from a mile away
http://autopia.org/forum/click-brag/...t=3000+unigrit
