LED Flasher
Old Dec 20, 2006 | 01:09 PM
Dabigman's Avatar
Dabigman
Originally Posted by Dj_AmtraX
Have you ordered the SB flasher to try?
Not yet, I was hoping one of the Lexus techs on this site could give us some more technical detail on the OEM flasher. It says on it, "+LED", so I'm wondering what that means and what the difference is betweeen ours and the 81980-02030 OEM unit.
I did find out that the SBLED unit, was replaced in production by the 02030 one.
Old Dec 20, 2006 | 02:47 PM
ABC's Avatar
ABC
CL Folding 100,000
What's the purpose of the flasher? To enable the right power to an led replacement?
Old Dec 20, 2006 | 02:53 PM
Dj_AmtraX's Avatar
Dj_AmtraX
You will have to change the front signal lights to LED too. Right?
Old Dec 20, 2006 | 04:29 PM
homer4598's Avatar
homer4598
An LED draws less power which makes the flasher unit think that a bulb has burned out. That causes the LED turn signal to flash more quickly than the normal rate.
Old Dec 20, 2006 | 04:32 PM
scrapp's Avatar
scrapp
Just so yall know, if it might help, LED turnsignals is a well known mod on motorcycles. To fix the problem, we buy these things.
http://www.cyclegear.com/spgm.cfm?L1...tem=MRX_FRH1_G
You might be able to understand it to use
Old Dec 20, 2006 | 05:07 PM
Dabigman's Avatar
Dabigman
Yes, that is a replacement LED flasher, the same thing we are trying to find.
Old Dec 20, 2006 | 05:09 PM
Dabigman's Avatar
Dabigman
The 50030 flasher the Tundra guy used worked in a mixed environment.
Old Dec 20, 2006 | 10:48 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Why go through all that hassle? Using load equalizers would be so much easier.
http://autolumination.com/equalizers.htm
Old Dec 21, 2006 | 12:25 AM
Dj_AmtraX's Avatar
Dj_AmtraX
Have you tried the resistors? Which one did you get?
Old Dec 21, 2006 | 07:54 AM
Dabigman's Avatar
Dabigman
To me, finding a plug and play mod is always preferable to cutting and splicing factory wiring. The resistors also get very hot, so you have to be careful where and how you mount them.
I might use the resistors after I exhaust my other options.
Old Dec 21, 2006 | 09:37 AM
Dj_AmtraX's Avatar
Dj_AmtraX
I agree. Please keep us posted.
Old Dec 21, 2006 | 09:51 AM
Hameed's Avatar
Hameed
EV ftw!!!
Not as simple as it appears.
I have tried the exact same load resistor as the one below and it did not do a thing on my car. Still hyperflashing like crazy.
I replaced the rear turn signals first and the hyperflashing started immediately.
Strangely enough, when you have the hazard flasher on (rather than just right or left turn signals), the LED's flash at the same rate as the regular filament bulbs.
I then replaced the front turn signals with LED's and same thing - hyperflashing.
I wonder if we can just remove the stock flasher completely out of the equation and resolve this problem like that?
Any Lexus tech here to confirm if this poses a problem or not?
BTW, I have a 99 GS400.
Old Dec 21, 2006 | 10:06 AM
Dj_AmtraX's Avatar
Dj_AmtraX
I have an idea! Have anyone tried the Toyota Prius & Camary Hybrid flasher? Both car have LED turn signals.
Old Dec 21, 2006 | 10:28 AM
scrapp's Avatar
scrapp
My friend bought some LED turnsignals off ebay with the resistors built in. Maybe this link will help, you just have to search ebay, when he gets online Ill see if he can give me more info
http://stores.ebay.com/US-Home-Direct/Problems.html
Old Dec 21, 2006 | 11:43 AM
chuckler's Avatar
chuckler
just curious what are the benefits of led flashers minus it never going out??
