Dead lights...HELP!
Old Feb 13, 2002 | 06:45 PM
lex400sc's Avatar
lex400sc
Default Dead lights...HELP!
Okay, my fog lights have been dead since I bought the car. Today I bought some new bulbs for it at the dealership and swapped them out, but still no good. In fact I tested the old bulbs out on a halogen desk lamp and they worked fine the whole time! To be honest, I don't know exactly how those fog lights are activated, but I tried every combo (headlights on, auto on, turn signals on, hazards on, high beams on, etc). No matter how they work, I'd ultimately want to wire them so that they turn on with the headlights. Anyway, I checked every point of the wiring harness up to the fuse box and all was good and tight. The only thing I can figure is that there's a dead fuse in the box. I opened the fuse box located behind the battery pan and about 40% of the fuses were missing. Is this normal? Do you guys have fuses inserted for every slot? How do I tell if a fuse is popped? Is it safe to just buy fuses for every slot and replace them all, even the empty ones? If this isn't the problem what else could it be? I'd hate to take it to the dealership for something that seems so basic.
Old Feb 13, 2002 | 07:22 PM
gadgetSC's Avatar
gadgetSC
Arrow Lights
Lex....not sure if its the same on th 95 an up years, but check the left kick panel on the drivers side. You have to pull-up the plastic door sil and pull back the panel with part of the carpet. There is another fuse panel. On the early years, the light fuses are located here. There are also a couple of relays for the lights. Hope this helps.
gadgetSC
Old Feb 13, 2002 | 07:26 PM
hwallen172's Avatar
hwallen172
My SC300 is a 95 and you have to turn on the fog lights by twisting a collar on the turn signal stalk. It's hard to see.
Old Feb 13, 2002 | 11:37 PM
methodmf's Avatar
methodmf
i believe the car have to be in drive
Old Feb 13, 2002 | 11:45 PM
lex400sc's Avatar
lex400sc
methodm:
That'll make it a little harder to test out, but thanks for the info. That could explain why I get nothing when I test it.
gadget:
Thanks, I'll check that panel out too. I'm sure they are the same from my year to yours.
hwallen:
I tried turning the stalk to every possible position, still no good.
Old Feb 14, 2002 | 09:08 AM
VQT's Avatar
VQT
The inside of fuse box cap should have a sticker showing what fuses go where and at what Amp.; therefore, if the sticker show 40% empty you're OK. If not you need to replace the fuses. The cap also has slot for spare fuses and a fuse puller. The kick panel fuse cap also has the sticker for the name and location of fuses for the box.
Question: What year did they change the turn signal light to Fog/Driving Light?
For my 93, when I turn the left signal light on, the left light stay on while the signal light blink. The same for the right side. It is good when turning at night.
Old Feb 14, 2002 | 01:53 PM
lex400sc's Avatar
lex400sc
I saw the diagram inside the cover, the spares, and the fuse clamp, but where does it show which fuses should be empty? On the diagram there is an ampere rating for every slot, so techinically I coud fill blank slots with correct fuses. Would this create a shorting issue? I don't know what year they changed that light or if they did at all. My manual says that's how those lights activate.
Old Feb 14, 2002 | 02:24 PM
VQT's Avatar
VQT
I would fill all the fuses in accordance to the back of the cover with the correct Amp. fuse. I remember where the slots are empty, the diagram would read 'spare'.
Do you have a repair manual?
What the manual read about activate the lights?
Old Feb 14, 2002 | 03:24 PM
SupraCoup3's Avatar
SupraCoup3
on this thought, what exactly do those emtpy fuse slots control? Daytime running lights? Hmmmm Could be interesting if you just plugged em all in w/ the right fuses.
Keep us posted.
Old Feb 14, 2002 | 07:24 PM
VQT's Avatar
VQT
Spare slot for extra equipment that you install like after market Fog Light (if you know how to connect to the fuse box). After market alarm system...
Keep us posted.
Old Feb 15, 2002 | 04:54 AM
Keith13b's Avatar
Keith13b
25 Year Member
Gotta back up VQT here -
Not really sure of the switch over, but try putting on your turnsignal. I know the first gen's have those fog lights as turning lights. Its a simple try and takes 2 seconds to do.
Also, for the other test, if it has to be in drive, just yank up the e-brake and go into drive. Test it first w/ you in the seat -
Old Apr 20, 2009 | 10:14 AM
MemphisSC's Avatar
MemphisSC
I've had the same problem with my 95 SC400. The fog lights are installed, and the bulbs are fine, and I also have the dial on the headlight lever set to on but I can't get the fog lights to come on. I looked at the fuse diagram in the manual and it showed two boxes with fuses. When I looked at the fuse box in the car, the second box that is supposed to hold the fog light and heated seat fuse is not there. My heated seats work fine, so I know that there is another box somewhere. Any clue where the second box should be?? Thanks!
Old Apr 20, 2009 | 11:02 AM
FuMoFFuTT's Avatar
FuMoFFuTT
Try signalling to turn right, and see if they turn on, then do the same for the left..
What year is your sc? they could be turning lights
Old Apr 20, 2009 | 11:50 AM
hwallen172's Avatar
hwallen172
On my '95, the headlights have to be on before the fog lights will come on. I never liked that.
Old Apr 21, 2009 | 03:48 PM
MemphisSC's Avatar
MemphisSC
my sc is a 95....they don't come on with the turn signals. I found more fuses higher up and to the right of the large fuse box, and when I pulled out the 15a fuse that should be for the fogs, it was not blown. I put a new fuse in anyway, and still no luck. Not sure what to check next.
Jezo
CT 200h Model (2011-2017)
Apr 17, 2019 09:39 AM
ohiois350
Oct 25, 2015 03:38 PM
4DGS
Sep 24, 2010 04:06 PM
//LRD
Aug 12, 2010 06:18 AM
Rockero28
Lighting
Mar 18, 2005 10:09 PM
