Custom make an intake heat shield for LMS
The truth is with a performance intake you WILL lose power in stop and go traffic and on a dyno. The reason for this is simple. By creeping along for 30 or more minutes at 45 MPH your engine really heats up or in the case of a dyno the intake is sucking hot air in from around the engine space. Since you are going slowly at an unsteady rate and/or sitting still, airflow into the engine bay is very erratic. This will force the air filter to suck in the hot engine air. (path of least resistence) Since hot air is less dense you will lose performance. However, on short trips, joyrides, or highway travelling, you will gain performance since there is a consistent cold airflow into the engine bay.
Is it worth it?
Many people including myself say YES! You may lose performance in rush hour, but are you really looking for more power when you are creeping along in heavy traffic? I doubt it. When you need that extra performance the performance air filter will give you that fun factor.
How can I get the most performance out of my air intake?
Most people will find that the performance cone air intake provides amp performance. However, others may want even more performance. How do you do this? By adding a Heat shield.
The best way to maximize the performance of a cool air filter is to build a custom heat shield. This will allow your air intake to suck in cool air all the time. Some companies make them but they are expensive, and you can easily build a better one yourself with less than and a trip to the home depot. What you want to do is isolate the cone air filter from the rest of the engine bay. (Which as we all know the LMS Intake does not do!) This will protect the filter from the engines hot air. It is best to close off as big of a space as possible to allow the enclosed area to hold more air (more air = better throttle response). Enclosing an area that doesn't have any place for the outside air to enter will still work, but it is best to enclose an area that has access to the outside air. I.E.. It is best to build a three-wall heat shield that is open in front to allow air to enter the area through the front grill. (In our case the 3 wall will be open towards the factory air inlet that is directing airflow from the front of the car.)
This is an example of what I'm talking about.
So getting an intake, to me may be a waste, vs the regular Drop in K&N... whenever that comes out.
How would the Intake resonator help performance?
Youre mileage usually improves 2-3 mpg with a K&N drop in, from what ive experienced
If you consider Manning's equation (below diagram) then you would assume that a larger smooth walled pipe would flow more air - it will (on a flow bench), but not into a piston engine
with a K&N drop in...
Yeah I'm thinking the same thing, that is why I'd like to make a heat shield. I do like the look of the LMS intake and the sounds are rather addicting, but I dont' want "all show/ no go" intake
JWT PopCharger w/ Heat Shield
I dunno, seems like the engine still was sucking hot air on my G. I guess it was better than nothing though.
no they make an intake with a heatshield. its not a CAI until its completely out of the engine compartment.
