video of seafoam treatment
Old Feb 11, 2006 | 01:47 AM
nicola's Avatar
nicola
Default video of seafoam treatment
I found this today online for those of you who haven't seen Seafoam in action: http://videos.streetfire.net/hottest...3DB1B41C75.htm
I had similar results with my GS400 with 115k on the clock.
Old Feb 11, 2006 | 08:36 AM
Xeeeeeem's Avatar
Xeeeeeem
Where do you put this seamfoam stuff in???
I hope you dont gotta take the intake pipe off by the throttle body and put it in there...
Old Feb 11, 2006 | 05:18 PM
Pheonix's Avatar
Pheonix
Cool
Multiple places. You can put it in the gas tank, crankcase (oil), and suck it in the intake to clean the combustion chambers.
They used it entirely incorrectly.
Search for Seafoam, and find the post I made regarding it.
Old Feb 13, 2006 | 08:17 AM
Xeeeeeem's Avatar
Xeeeeeem
My car won't stay on if the intake is off the throttle body at all, no matter how much gas i give it.
Where did these guys put their seafoam to make it cloud like that.
I think thats the only way i'd be convinced its working if it smokes that bad.
Old Feb 13, 2006 | 01:26 PM
nicola's Avatar
nicola
Any vacuum port on the intake manifold. What kind of car do you have?
Old Feb 13, 2006 | 05:24 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
make sure u have the maf plugged in, sometimes the ecu juss kills the motor when it doesnt recieve a maf signal.
Old Feb 13, 2006 | 06:34 PM
Pheonix's Avatar
Pheonix
Cool
If you have a 3L dump out 1/4 of a can, if you have a 4L+ use 1/3 of a can into a container
Take your brake booster line off the brake booster side & put your finger on the end so it's not a vacuum leak & the engine will run.
Drop the line in the cup & take your finger off.
If it doesn't instantly die, CUT IT OFF.
Wait EXACTLY the specified time & re-crank the engine.
After that you'll want to let it iddle a few min for the smoke to die down.
Then drive it around, and before it all burns off, drive the B like you stole it for abit.
Repeate that sevearl times and you'll get a combustion chamber as pretty as mine!
See my seafoam post
https://www.clublexus.com/forums/sho...d.php?t=185227
Old Feb 14, 2006 | 03:54 PM
Psionic's Avatar
Psionic
Did it on my 92 SC300 w/ 190k on it... looked just like that. Also did it on a friends 95 corolla with 127k on it... his looked worse than mine.
Did it on my 99 Expedition... no smoke whatsoever
Old Feb 14, 2006 | 09:20 PM
Xeeeeeem's Avatar
Xeeeeeem
95 gs 300. I don't unplug the MAF sensor. just loosen up the the ring that goes around the throtle body and took that off. It just doesnt stay on AT ALL
Old Feb 14, 2006 | 11:25 PM
nicola's Avatar
nicola
You really need a vacuum line for this. Loosening the throttle body intake gasket is too much air loss.
Old Feb 19, 2006 | 10:07 PM
LexAnt's Avatar
LexAnt
what about the seals? I mean like we've all heard stories where there's some carbon or gunk that actually helps hold a seal. If the seafoam gets rid of this, leaking could occur. This is my only concern right now before I do this. I got 2500 miles left before an oil change, so i'm researching on this before I do it.
Would seals prove to be a problem with seafoam?
Old Feb 20, 2006 | 11:23 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Seafoam is the most highly used and widely acclaimed product on the market with millions of good praises. Don't over think it, just use it.
Old Mar 1, 2006 | 10:02 PM
ducker9mm's Avatar
ducker9mm
Hey can i get some help? I tired to put seafoam down my SRT intake and it wouldn't suck it up.
i pulled one of the hoses off and stuck it in a cup, but it wouldn't work. This is on a 99 GS400.
What am I doing wrong?
tman6925
Performance
Jul 7, 2015 08:18 AM
speedmike
Dec 11, 2012 06:43 PM
