TCC Reviews the Mitsubishi Evo IX
Old Aug 29, 2005 | 07:53 PM
Variance's Avatar
Variance
Default TCC Reviews the Mitsubishi Evo IX
Link: http://www.thecarconnection.co....html
2006 Mitsubishi Evo IX
After a steady diet of V-8s, a screaming turbo four sorbet.
(2005-08-29)
By Conor Twomey
The first time I drove an Evo was about two years ago just before I moved to the U.S. In Europe, the Evo is held in near Ferrari-like esteem and garnishes respect and admiration wherever it roams. It's a car that suits Europe's challenging driving conditions absolutely perfectly-not surprising given that each Evo was developed to comply with FIA regulations that specify a certain number of street cars must be produced before a carmaker can go rallying.
I was absolutely blown away by it. The Evo and I simply connected. There was a real chemistry between us but, alas, our romance was fleeting and we had to part ways after only a few days.
Two years of gorging on rear-drive V-8 muscle and the Evo and I meet again. I'm nervous. Will the chemistry still be there? Has my delicate European palette been sullied by the smoky taste of slow-cooked tires roasted over a V-8 spit coated in tail-happy sauce? Am I still able to appreciate its finesse or, worse yet, will it prove to be a silly irrelevance in a country with so much more space than an Evo needs to look its best?
Working it out
While I've been getting flabby, the Evo has been working out and looks better than ever in its new IX guise. The new front bumper exposes more intercooler cleavage than before, which is never a bad thing, while the front and rear light clusters are tinted and… erm… that's about it. The rear carbon-fiber wing is hollow now and there are new Enkei wheels on the RS and straight-up Evolution models and that's all she wrote on the styling front. Japanese and European models get a sexy new rear bumper, too, with a built in air diffuser but U.S. cars won't get it for some reason. It's still a great looker, though, bristling with raw aggression and seething intent.
There's new muscle, too. Thanks to the addition of variable valve timing on the intake camshaft of the 2.0-liter intercooled and turbocharged four-cylinder engine, as well as a new turbocharger compressor housing and improved muffler, the Evo IX now pumps out a healthy 286 hp at 6500 rpm, an increase of 15 hp. More significantly, there's now 289 lb-ft of torque at 3500 rpm, which makes the Evo considerably more driveable on a day-to-day basis as well as making the car more forgiving of poor gear choices. And Mitsubishi has even made choosing the wrong gear a little more difficult by revising the ratios on the five-speed gearboxes for better acceleration. Mitsubishi doesn't talk about how fast it is probably because that insights owners to ripping the drivetrain apart doing pointless standing starts, which would also explain the 5500-rpm rev limiter on the car when its stationary, but even with the electronic nannies we estimate that the 0-60 mph time to be around four-and-a-half seconds and top speed is more than 150 mph on the MR model.
The Evo's got more brawn than ever and it's a little cleverer, too. Now all Evolution IX models use an electronically-controlled, multi-plate center differential that can be adjusted depending on the road conditions (snow, gravel, tarmac). It constantly tweaks the front/rear torque bias based on a constant stream of data regarding steering wheel angle, throttle opening, wheel speeds and longitudinal and lateral movements of the vehicle, to keep you between the green bits and on all four wheels. The open front differential of the old Evo has been ditched in favor of a new helical limited-slip differential - the difference being that while on open diff sends torque to the wheel with the least grip, the helical LSD channels torque to the wheel with the most grip. As a result, you can now get on the power earlier in a corner because instead of lighting up the unloaded inner tire, the outer wheel can now bite into the asphalt sooner and get you rocketing to the next corner even faster. The rear axle keeps its tough, plate-style 1.5-way mechanical LSD and the ABS system has been recalibrated so it doesn't intervene as aggressively as before. As with every evolution of the Evolution, the changes are subtle but effective. More about that later.
Triple threat
Three models are available in the U.S. and all share the same powerplant, the same Brembo brakes (four-caliper front and two-caliper rear), the same basic bodywork and the same drab interior fittings. The RS is the track specialist, with an aluminum roof and thin-metal trunk lid and it also sheds its power windows, painted mirrors and door handles, rear wing, stereo, remote locking, aluminum pedals, map lamps and intermittent wipers in the name of weight, performance and cost. It forfeits its ABS and EBD, too, thought the turbo gauge cluster is standard and it keeps its air-conditioning unit also.
The Evolution MR also gets the aluminum roof panel but has its own special Bilstein monotube shocks, lightweight 17-inch BBS alloy wheels, a more sophisticated hydraulic central differential, a six-speed transmission, Xenon lights and a Vortex generator. The mid-line IX models has the same mechanical set-up as the RS but keeps the deleted items listed above with the exception of the turbo gauges, aluminum roof and lightweight trunk lid. The RS, IX and MR models should be priced at $29,000, $32,000 and $37,000 respectively which means for the price of a drab family sedan you can have genuine, super-car eating uber-performance while sacrificing none of the practicality.
So what makes the Evo and me sizzle like Brad 'n' Angelina? Well, just take the engine, which now delivers its punch in a more linear and less laggy fashion, coming on full boost earlier propelling you forward at an alarming rate thanks to excellent traction and savage torque. The gearbox is monumental - slick and lightweight with a perfect gate whether it's the five or the six-speed box. Those Brembo brakes haul the car down from silly speeds repeatedly on the track with no sign of fade or sogginess. The pedal requires more of a shove than I remember on the European models I last drove so heel-toeing isn't something you can do easily if you're really spanking it hard, though these cars have been around the track a few times so might be a little tired. Fortunately, the engine and transmission are quite happy to slot into gear smoothly even if you can't blip the throttle and no matter how brutal you treat the transmission it never complains or threatens to blow up.
Brilliant positioning
The driving position is another jaw-droppingly brilliant feature of the car. I'm only six feet tall but with a helmet on I find it difficult to fit in most other cars without severely compromising my seating position. In the Evo, I'm sitting upright, with my legs out straight and my hands slightly bent at the elbows, just where I want to be. The standard Recaros hold me in place so well I'm not really aware of the 0.98 of lateral G I'm able to generate until something flies across the car and explodes against a door and even the size and thickness of the Momo steering is perfectly calibrated for my sweaty, tingly palms.
But what really sets the Evo IX apart is the way it goes around corners. In tight bends, where the old car would understeer and spin its power away, the front end of the new Evo grips so much earlier and it can even be provoked into power oversteer if you're aggressive enough and ballsy enough with the throttle and steering. You'll have to fight some pretty intense torque steer to make it happen but once you get used to unwinding the steering lock yourself you can perform all kinds of crowd-pleasing slides in roundabouts and tight radius corners. The trick diffs are noticeable at higher speeds, too, allowing you to pitch the car more sideways than before and hold it there for as long as your skill and available tarmac allows. Throttle adjustments can be used to rotate the car on an invisible axis making the Evo incredibly adjustable and intuitive on the limit.
In simple terms, all the feel and feedback of the VIII is preserved in the new model but thanks to some small improvements here and it's slightly more chuckable, fractionally faster through corners and a wee bit more amusing than it was before… which is saying something. I think the Evo IX is more fun than just about any other car on sale in America today and every bit as home on American highways and racetracks as it is across the pond. The passion between us still exists even if our reunion was all-too-short. Until next time, mio amore!
2006 Mitsubishi Evolution IX
Base price: $29,000 (est.)
Engine: 2.0-liter in-line four; 286 hp, 289 lb-ft
Drivetrain: Six-speed manual transmission, all-wheel drive
Length x width x height: 178.5 x 69.7 x 57.1 in
Wheelbase: 103.3 in
Curb weight: 3263 lb
EPA (city/hwy): 18/26 mpg
Safety equipment: Dual front airbags, anti-lock brakes, electronic brake distribution, fog lamps
Major standard equipment: Air conditioning, keyless entry, HID headlamps, rear defroster, tilt steering wheel, six-speaker CD audio, aluminum sport pedals and shift ****, Recaro front sport seats, MOMO steering wheel, BBS forged aluminum wheels, W-rated tires
Warranty: Three years/36,000 miles; five years/60,000 miles powertrain
Larger versions of the above pics are available at TCC.
Old Aug 29, 2005 | 09:37 PM
LexFather
Guest
Posts: n/a
This car is just a beast in every which way
Old Aug 30, 2005 | 10:10 AM
ST430's Avatar
ST430
The new front air damn looks great. I'm really tempted to pick up an RS just for weekend fun...drove a regular evo version and it's steering was so communicative and razor sharp!
Old Aug 30, 2005 | 06:00 PM
GFerg's Avatar
GFerg
Speaks French in Russian
CL Folding 25,000
Damn. I really love this car even more than before. It looks even more beastly. Great job Mitsu. Only if the rest of the lineup will follow suit.
Old Aug 30, 2005 | 06:27 PM
GS wanted's Avatar
GS wanted
finally people stop bashing the Mitsu platform. not a fan of the styling but the size and power-to- weight ratios are impressive. especially for a 2 liter 4 cyl.
Old Aug 30, 2005 | 09:04 PM
4runnin's Avatar
4runnin
O MY GOD,,,,,,,,,,,,,,,,,,,,,,,,,,,, that car is soooooooooooooo bad ***!!!!!!!
Heres a evo8 rockin a Ferrari from a roll, that dood musta been PISSED. LOL!!!!
30,000 dollar car VS. a 120,000 dollar car.
Evo------Vs.----ferrari from a roll
Heres one more sweet one, evo8 vs two totaly tricked out blown nitro cobras.
Both smoked!
Cobras Suck!!!!!!
Old Aug 30, 2005 | 09:09 PM
GFerg's Avatar
GFerg
CL Folding 25,000
HAHAHAHAH!! My man was for real hyped in that video. Good stuff.
Old Aug 30, 2005 | 09:14 PM
4runnin's Avatar
4runnin
LOL, howd u like to be the guy in farrari gettin toasted by a ricer, only to look over and see 2 punks laughin at him with a video camera on his car!!!!!
Old Aug 30, 2005 | 09:34 PM
pilip99's Avatar
pilip99
evos are awesome, nice vid link
SVT2888
Sep 20, 2012 04:40 PM
edgy
Sep 23, 2008 08:46 AM
GFerg
Sep 13, 2006 01:50 PM
jimxo
Jan 29, 2004 10:12 AM
UZZ32
Oct 15, 2003 06:35 AM
