Can Goodyear's Fortera 235/70/16 SUV tires fit the 2001 RX300? (OEM size 225/70/16)
Old 10-10-02, 07:29 PM
sleepybobcat
Registered User
sleepybobcat's Avatar
Default Can Goodyear's Fortera 235/70/16 SUV tires fit the 2001 RX300? (OEM size 225/70/16)
I'm concerend about the rear tires coming in contact with the
rear strut. With OEM tire(225/70/16), there is about 3/8" to 1/4"
of clerance.
Many members have used Michelin CrossTerrain in 235/70/16
without rubbing problems... Is it safe to assume that the
Goodyear Fortera 235/70/16 will also be fine?
Also, has anyone actually used these tires? If so, how do you
like them?
Thanks for your help!
Old 10-11-02, 12:55 PM
sleepybobcat
Registered User
If I order these Fortera 235/70/16 tires from the Tire Rack
and the rears don't fit, can I get a refund? (tire mouted on wheel
and put on the vehicle, without touching the ground)
Old 10-11-02, 01:39 PM
GS4Will
GS4Will's Avatar
just ask tirerack on their return policy..i am certain should be ok
davidyal
RX - 1st Gen (1999-2003)
07-04-11 05:48 AM
tomjode
10-21-07 12:00 AM
krock
06-27-04 11:11 PM
Quick Reply: Can Goodyear's Fortera 235/70/16 SUV tires fit the 2001 RX300? (OEM size 225/70/16)
