Tire maximum load question
Old Nov 28, 2010 | 07:35 PM
I8ABMR's Avatar
I8ABMR
Default Tire maximum load question
Hey guys I just picked up an LS460. I am going to do a set of Vossen VVS082's. I keep seeing that many owners are using a 245/30/22 in the front. My question is that when I was using a 245/30/20 it wasnt rated high enough to hold the weight of my GS. So is it safe to assume that a 245/30/22 will not have the rating to hold the heavier weight of my LS460. I am thinking of doing a 255/30/22 and 295/25/22 as opposed to the common 245/30/22 and 285/25/22. Any suggestions??
Old Dec 3, 2010 | 02:11 PM
Brandon@TR's Avatar
Brandon@TR
Former Sponsor
The amount of weight a tire carries is directly related to it's size. A tire on that car would need to carry 1300lbs per tire minimum.
Old Dec 3, 2010 | 03:01 PM
vwynn's Avatar
vwynn
whats the load rating on those tires? and whats the load rating on your OE tires?
if its the same or higher its ok... if it lower like many of the stretch guys then be careful.
lkapimp216
VIP Style
Jan 26, 2011 03:42 AM
I8ABMR
Nov 25, 2010 12:25 PM
LexiGS
Sep 28, 2009 09:01 AM
G3Johnson
Jan 17, 2008 07:51 AM
J-RO
Jun 4, 2007 11:37 AM
