what are the pros/cons of a reversed lip?
Old 02-21-07, 10:21 PM
RanGer498
RanGer498's Avatar
Default what are the pros/cons of a reversed lip?
I see some wheel companys like
-Iforge
-Dpe
and others whom have reversed lips on there wheels,what is the pros and cons in this ?
i would think water would get trapped in teh middle of the wheel well and cause shaking or at the least thow off the alighnment due to this .
anyways im asking to learn
thxs
Old 02-22-07, 09:08 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
pros - allows deeper dish
cons - none, other than when mounting, the face is towards the ground putting it in dangers way of the clamps on the wheel mounting machine - not a bad thing if the tech knows what they are doing, but definitely not for the noob tire changer..
Old 02-25-07, 02:15 PM
ant1k
ant1k's Avatar
its all a matter of preference. no cons except that wheels with deeper lips tend to crack or bend if you hit them hard enough in a pothole ect.
Old 03-01-07, 09:13 PM
Vic Nyce
Vic Nyce's Avatar
<<<noob. what is a reversed lip?
Old 03-01-07, 10:55 PM
mitsuguy
mitsuguy's Avatar
true definition - a weel that has the "drop center" towards the backside of the wheel instead of the frontside... the drop center is the depressed area in the wheel that is used to give some slack to the tire in order to mount it... almost every wheel with a 2" or better lip will have to be reverse mount, as a tire simply won't stretch more than that to mount...
BGG
08-20-12 08:45 PM
Dx3
01-15-10 09:08 AM
SPEED&ECO.
11-04-07 02:32 AM
HuangE46
04-05-07 03:10 PM
lexbuble96
CL of Southern California
08-07-05 08:31 PM
Quick Reply: what are the pros/cons of a reversed lip?
