Aspect Ratio for 19's
Old 10-04-06, 04:24 AM
klthomas
klthomas's Avatar
Default Aspect Ratio for 19's
For 19's, wouldn't 235/40/19 go just as well with 275/35/19 as 245/40's? I usually see the 245/275 combination instead.
If i understand correctly,
275 x .35 = 96.25
235 x .4 = 94.0
245 x .4 = 98.0
So they are both about the same difference from the 275/35.
I am looking for tires on my 19 x 8.5 35mm and 19 x 9.5 45 mm wheels. I am little worried about rubbing and I think the 235/40/19 may be just enough smaller to where it isn't an issue.
Or does 235/40/19 go better with 265/35/19
265 x .35 = 92.75 I guess that is a little closer.
Maybe I should just go for the 245/275 combination and quit worrying about it.
Any suggestions?
Old 10-04-06, 06:53 AM
4TehNguyen
4TehNguyen's Avatar
you have to match the overall diameters of the stock wheel/tire combo with the aftermarket combo so you can minimize error in the speedometer
Old 10-04-06, 07:41 AM
skeet94
skeet94's Avatar
I've currently got 285/35/19 (rear) and 245/40/19 (front) and I'm having no rubbing issues whatsoever except when backing out or doing a full lock turn whilst creeping forward. Otherwise no rubbing issues whatsoever . Rear has 1 finger gap on stock suspension and front has about 2 1/2 - 3 finger gap...just need to get some money over to Jeff for his coilovers now.
Speedo is off by 5mph, but as long as you keep an eye on the speedo when you're near cameras you're all good .
Old 10-04-06, 08:01 AM
AZDesertGS
AZDesertGS's Avatar
Depends on the tire brand but 235/35 and 275/30 match up better for the overall diameter. With your rims you are looking at I would say a +35 offset for the rear would be better then the +45.
Old 10-04-06, 09:02 AM
rominl
exclusive matchup
rominl's Avatar
technically 245 is better match with 275, and 245 is better match with 285. but that also depends on the width of rims you putting the tires on, whether there are stretching or not, etc...
Old 10-04-06, 09:16 AM
Neo
The One
Neo's Avatar
Huh? Rom?
I like the pairs as 235/275 and 245/285 with preference to the 245/285 combo.
Old 10-04-06, 09:32 AM
rominl
exclusive matchup
rominl's Avatar
sigh..... what a long day to come @_@
Old 10-26-06, 06:55 AM
TactiCOOL
TactiCOOL's Avatar
well i have 19x9 and 19x10.5
Plan on Running
245/35 and 275/30
vinnier6
04-03-16 09:13 AM
eliteskill
SC- 1st Gen (1992-2000)
29
03-24-10 02:44 PM
tarponman
09-16-09 11:58 PM
MAS
VIP Style
09-04-08 04:57 PM
SnShne1jz
08-10-07 08:38 AM
Quick Reply: Aspect Ratio for 19's
