psi question
Old Feb 27, 2004 | 08:47 PM
elclassico's Avatar
elclassico
Default psi question
im running 18x 9. 245 wall. lowered with stiff suspension gs. i like to keep my psi way lower then the side wall suggests? also tire shops always over inflate your tires. what are some of you guys running? 30 psi? do you keep it the same all the way around? or is it better to keep the rear at a higher psi then the front?
on a side note i got my tire patched from the inside (damn screw) i was told this lowers the speed rating by 10 mph??? also i was told they didnt need to rebalance b/c they mark the tire. so does that even have any relevance or is it so minimal its just a technicality? any input would be greatly appreciated. thanx to all.....
Old Feb 28, 2004 | 12:38 PM
PHML's Avatar
PHML
Master Thread Closer!!
48 psi all around (51 psi max ) to prevent damage to my wheels due to dang potholes.
Old Feb 28, 2004 | 04:03 PM
elclassico's Avatar
elclassico
good point. thanx. also theres gas milage. is 25 too low? as far as the tire coming off the rim?
Old Feb 28, 2004 | 04:56 PM
Neo's Avatar
Neo
The One
38psi for me.
32 is too low and stay away from 25. I think with 18s, you should be above 35 to help protect the rims.
Old Feb 28, 2004 | 05:01 PM
elclassico's Avatar
elclassico
ok, i just did 35 all the way around. 25 did seem a bit low. thanx for the suggestions.
Old Mar 1, 2004 | 12:24 AM
rominl's Avatar
rominl
exclusive matchup
wow, that's SUPER high pressure!
i think 38 is a good number. if you have 19s or 20s then 40 to 44 is a good number
Old Mar 1, 2004 | 02:10 AM
PHML's Avatar
PHML
Yep...mines are hard as rock....nah....not that bad...the Michelins really help.
Aliiciia
Jul 7, 2016 01:25 AM
kqt2ktval
Jul 7, 2012 12:05 AM
sj408
Nov 9, 2009 10:49 PM
IStoGS350
Dec 16, 2008 08:25 PM
LCSC
Dec 6, 2007 06:09 PM
