Wheels and Tires Classifieds All rims and tires for sale belong here.
Hubcentric Rings for 2IS
Old Jul 11, 2006 | 05:50 AM
MrMark's Avatar
MrMark
Default Hubcentric Rings for 2IS
Slightly used set Metal Hub Centric Rings for 2nd Gen IS. These are not the Poly Carbon rings but made of metal which are much better quality than plastic/poly carbon rings and are made to a more exact, closer tolerance for a proper fitment. They won't crack, melt or break over time like plastic rings do.
Rings will fit the hub of the 2nd Gen IS and have a 60mm inside diameter and a 73mm outside diameter.
To check fitment, use a mic and measure the hub of your car and that will mach the inside diameter measurement, and measure the inside hole of your wheel and that will be the outside diameter measurement.
Rings are in excellent condition…
$18 for the set of 4 shipped to the lower 48.
mryuen@usa.net
peterls
Aug 8, 2014 09:17 AM
GS1stgen
GS - 1st Gen (1993-1997)
May 2, 2007 05:57 PM
MrMark
Jul 24, 2006 02:39 PM
IS0LD0UT
Wheels, Tires & Brakes Forum
Oct 24, 2005 10:19 PM
b1gredek
Jun 6, 2005 10:11 AM
