Airlift ECU not found help
Old 07-17-16, 07:24 PM
RobzKar
RobzKar's Avatar
Default Airlift ECU not found help
Hey guys so I took the plunge and purchased an Airlift 3h3p for my car and I'm having an issue with it. At first after I installed it it worked and was Kool, I was having fun playing with it since it is my first time on air, then later on in the day I went back to mess with it some more and as soon as I turned the car I get a ECU not found on the controller. So I check all the wiring all the fuses and nothing. So I disconnected the battery and left it alone for a good 30 min and tried again and nothing. The next morning I fired it up and boom it starts working so I was like Kool. Well later on again that day ECU not found. I've called airlift during this entire issue and they have been really helpful. They are also exchanging the manifold for me and sending me a new one. But I am still wondering why it was doing that. Any body have same issue and maybe found a solution for this, I'm not certain it is the manifold until I switch it out. Any input would be appreciated. Thanks
Old 07-17-16, 07:35 PM
RobzKar
RobzKar's Avatar
Heres pic of the car
Old 08-04-16, 07:48 PM
RobzKar
RobzKar's Avatar
Ok so since no one chimed in on this thread I figured what the problem was. Through process of elimination first the manifold then the controller finally the main connector. It was the cable that ran with the main connector that connects to the USB cable of the controller. So there you go if any one has this issue there it is. Through out the whole issue Airlift was there helping me and changing out what needed to be replaced. Great customer support.
Old 09-21-17, 12:59 AM
lowKut
NELOC Moderator
lowKut's Avatar
Good to know AirLift offer excellent customer support service . I am looking to get the 3P kit.
Old 07-23-18, 05:19 PM
Tre350z
Tre350z's Avatar
Default Parts location
where did you find the parts at? Could you send me a link please?
GS FONZy
Performance & Maintenance
02-04-17 04:40 PM
dandd2
01-24-13 07:16 AM
MrSlopra
10-17-12 08:57 PM
3UZTaco
05-04-08 07:00 AM
Quick Reply: Airlift ECU not found help
