Post The Trunk SetUp
Old Sep 30, 2013 | 10:48 AM
  #181
Riksgs808's Avatar
Riksgs808
Originally Posted by BBRolex
Where did you guys put the air line through in the trunk? Did you guys drill holes? And swtjlsy, can you explain how the lines will melt? Sorry I'm new to all of this lol
I drilled holes for the rears. Drilled right through fender wells into trunk. I ran the fronts through yhe firewall into the cab, and ran them into the trunk. Yes, the lines coming out of vu4 will eventually melt from the hot compressor lines.
Old Oct 1, 2013 | 08:10 AM
  #182
swtjlsy's Avatar
swtjlsy
the compressors leader hoses get very hot and you have them routed right on top of your soft lines which over time will melt though them and make a leak. it a easy fix just run the lines the other way turn them 180 degrees the other way
Old Oct 6, 2013 | 07:35 PM
  #183
Sc0pe's Avatar
Sc0pe
All you guys are probably gonna start crying from laughter, but here goes!
Just finished wiring it up today - took a week and two days to complete (WAY TOO LONG but I lacked the proper tools - also, installed a new head unit). In its final form though (which will probably come around in 6 or so months), expect to see some lights, hardwood flooring and plexiglas.
Old Oct 15, 2013 | 10:53 AM
  #184
Dapper's Avatar
Dapper
So much win in this thread! I'm ordering parts for my air setup now and these setups are giving me so many ideas. Can't wait to join you guys!
Old Oct 25, 2013 | 02:58 PM
  #185
vipXjunky's Avatar
vipXjunky
I see what you guys are saying now... Thanks for the explanations!
Old Dec 8, 2017 | 06:54 PM
  #186
GS300Chris's Avatar
GS300Chris
Not as cool as some of your guy's but here's my start. Manual air, and a little rough around the edges.
Old May 29, 2018 | 01:47 PM
  #187
onthelo's Avatar
onthelo
anyone else in here running air setups haven't seen any new post in awhile
Old Aug 9, 2018 | 09:20 AM
  #188
onthelo's Avatar
onthelo
Thought I would add my trunk build into the thread I just finished it up. The entire enclosure inside is wrapped with suede, has push and pull fans and adjustable LED lighting. All the components are under 1/2" plexiglass. I built it into the spare tire well so I could still use my trunk and keep everything easily serviceable.
Old Jan 9, 2020 | 06:24 PM
  #189
Laidlexon2's Avatar
Laidlexon2
Default My GS300
Old Aug 9, 2025 | 09:29 PM
  #190
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Talking
Originally Posted by Laidlexon2
This is a super late reply but I love your GS!
metaleckz
Dec 5, 2019 07:00 PM
3isdanny
Suspension and Brakes
Sep 20, 2016 10:39 PM
TomLee
Sep 18, 2012 04:42 PM
themachine
Sep 10, 2010 09:53 PM
Benjamin T
Aug 1, 2007 07:49 AM
