Finished bagging my Q
Old Dec 28, 2007 | 03:47 PM
  #31
DriftGirl's Avatar
DriftGirl
kinda makes it easier to part with the GS eh?
Im kinda on the fence about camber, I like yours but not anything more extreme than that.
Id run thru sooo many tires LoL!!
Old Dec 28, 2007 | 05:30 PM
  #32
Balling's Avatar
Balling
Originally Posted by golfkid777
All work done by me, all custom setup. Uses UAS Aerosport bags with Algernon Coilovers. I have at least an inch more adjustment I can do in the front to go lower just need to find time to trim and roll the fenders and this thing will be about as low as the rrear in the front.
dont forget to either notch, and hammer up (lie i did) the front frame rails.
not alot, but a little arc above hte tires, it iwll give you another half and inch or so
Old Dec 28, 2007 | 08:08 PM
  #33
golfkid777's Avatar
golfkid777
I got it sitting half an inch lower, ill see about hammering up those and seeing if that makes any difference. New pics soon.
And ya its a lot of camber but it drives really nice and hendles extremely weel for the camber at slightly above normal drive height.
Old Dec 28, 2007 | 09:20 PM
  #34
takumi117's Avatar
takumi117
you got pics of the set up?
Old Dec 29, 2007 | 05:54 AM
  #35
Balling's Avatar
Balling
he has hte same setup as me, same brand, i just did an S13 front suspension conversion to get more camber, and more perforamnce oriented coilovers.
Old Dec 29, 2007 | 11:50 AM
  #36
golfkid777's Avatar
golfkid777
My coils do look different than those though, not as much threaded area on the rears, but my tire is still sitting on the underside of the fenderwell when all down in the rear.
The fronts are a lot lower, but I still want to go lower, just some more tweaking and more adjusting should do the trick.
Old Dec 29, 2007 | 05:16 PM
  #37
Balling's Avatar
Balling
yeah, they adjustability is different on the y33 shocks
thats why i did the s13 all around
YOU can get some S13 rear coilovers BTW....they bolt rigth in after you swap tophats.
Old Dec 29, 2007 | 06:35 PM
  #38
golfkid777's Avatar
golfkid777
Yeah but I couldnt lower the rear of the car another mm if I tried. It already sits on the inner fender tubs.
Old Dec 30, 2007 | 04:47 AM
  #39
Balling's Avatar
Balling
thats what a hammer, roller and camber is for
why you think i run so much camber?
If you get a good roller, a torch, and a hammer, you can actually push taht inner tub up and twards the inner fender. to get almost 2 inches clearance.
Old Dec 30, 2007 | 10:13 AM
  #40
golfkid777's Avatar
golfkid777
Well damn... ill have to get under there and see what I can do because id love to be able to drive at the height im at.
Old Dec 31, 2007 | 04:18 AM
  #41
Balling's Avatar
Balling
yeah bro, seriously, add a 15mm spacer, run a few degrees more camber, put in a few hours of heating rolling and banging, and you will be non rubbing in no time
My emitz, i can drive anywhere, with it fully slammed, my bumpers drag, but nothing rubs at all.
Old Dec 31, 2007 | 10:07 AM
  #42
golfkid777's Avatar
golfkid777
I am happy with the camber and fitment right now. I think my camber is just at the point where anymore doesnt look good, so Ill just leave it there, I just want to be able to roll at 0psi so slamming it goin down the freeway is not as violent an experience. I am sure once i get a kit and am in the process of an entire new paint job, Ill be doing some work to get the kit lower, but until then I just want to be able to drive at the height I am at now all down.
My fronts sit just as low as yours do with your new emitz.
Old Dec 31, 2007 | 10:07 PM
  #43
speedaddic's Avatar
speedaddic
Golfkid,,,I don't miss your GS now that I see your Q...looks HOT man
Old Dec 31, 2007 | 11:04 PM
  #44
El Captain's Avatar
El Captain
looks so sick congrats man! Hoqw long did it take for the entire install!
Old Jan 1, 2008 | 01:29 AM
  #45
golfkid777's Avatar
golfkid777
Install was about 30 houres total. But thats custom fabbing everything.
