Changed oil, feel like I am driving a different SUV
So i just hit 1500 mi on my TX550h+. I decided it was good to just change the oil to keep the engine longevity. After much research i settled on the Valvoline restore and protect 0w20. Went in for a quick oil change. 1st thing - oil levels from factory were low. 2nd, after the oil change the car is running so much smoother (likely the oil type) and I am exceeding MPG when on gas only.is around 32-33 on city on my first full tank.
Anyone else experience this?
I think Lexus mentioned that free oil change is at 10K miles for 1 time only. They can check and rotate tires at 5K miles.
I do believe that thinner oils are known to improve gas mileage slightly. This is one reason oil recommendations for the same cars and engines sold in the USA are for lighter oils then other countries. Helps to meet gas mileage requirements. Unfortunately at the expense of engine life. But of course this also depends on how the car is used. I would assume lighter oils are better for cars driving relatively short distances with more engine starts, since the lighter oil will provide better protection while the engine warms up. I.E., in the end it depends.
If there really is a difference you can feel, I'd be surprised it's from an oil change. More likely something else was effected. Especially if you had it done at the dealership. Perhaps they did a firmware update while they had it?
