TX Models (2024-present)
Battery issues with 2025 TX-350
Old Nov 19, 2025 | 08:25 AM
Grumpy2's Avatar
Grumpy2
2nd gear
Default Battery issues with 2025 TX-350
I just purchased a slightly used 2025 TX-350 with 1,300 miles on it and have had what appear to be battery/power problems with it over the last several weeks. Toyota installed "380LN3-ISS" batteries in this model - apparently, the same battery that they have been installing in their Toyota line of vehicles. Can someone explain to me WHY they didn't use a heavier-duty battery, given the heavy use of power needs in the TX-350?
Old Nov 19, 2025 | 04:29 PM
LawyerRon's Avatar
LawyerRon
7th Gear
My guess is they probably installed the same battery used in the Grand Highlander as they are essentially the same platform. Nothing wrong with assuming they used the correct battery. I suspect you have some sort of other electrical issue going on and the problem is not the battery.
Old Nov 20, 2025 | 07:16 AM
SeniorNotso's Avatar
SeniorNotso
I was surprised that Toyota didn’t use an AGM battery due to the heavy constant use of the battery prior to and after turning on/off the engine. AGM’s, I believe are designed to be used in todays heavy use batteries?
Old Nov 20, 2025 | 12:27 PM
Grumpy2's Avatar
Grumpy2
2nd gear
Yes, I agree. Interestingly, when I took it back to the dealer and they load tested the existing battery, they found it to be defective and they replaced it with an 84-month Lexus-brand battery.
Old Nov 22, 2025 | 07:55 AM
SilverElegance's Avatar
SilverElegance
Just a bad battery - it happens
AMIRZA786
Mar 17, 2024 08:32 PM
chrshea
Hybrid Technology
Feb 12, 2022 11:31 PM
Cghor45
Oct 6, 2021 08:45 AM
Sclppy
CT 200h Model (2011-2017)
Aug 30, 2021 08:31 AM
GFerg
Mar 17, 2013 01:02 PM
