First Gen Offset Question
We need to know how wide the wheels are! For example, on my brother's (Link 13) '94 GS, we used 19x9 +37 and 19x10 +37. This rear offset & width require rolling the rear fender slightly, but we wanted an aggressive look. The fronts fit perfectly, with no mods.
In contast, a 19x8.5 or 19x9 +37 all around will require no modifications.
first gen only
On the first gen gs300 you can't go wider than 8.5 in the front without scrubbing the inner fender, but if you don't mind scrubbing the inner fender then run a 9.0, but to play it on the safe side stick with the 8.5 in the front and 9.0 or 9.5 in the rear.Hope this helps.
How will 18 x 8.5 +42 offset all around work
I would use a 245/40-18 tire.
Thanks socal. Just a few more questions. so what's the best offset for a first gen gs300? and if i were to buy rims with a +42 offset i would need spacers for the best look? Thanks again.
Thanks toothbrush. So to clarify. +35 is ideal (no need for spacers,) but if I get +42 then get 5mm spacers up front and 10mm in back? Thanks again.
