Really need help for mag fitment
I've search and search since i know nothing about wheels fitment. I have a Lexus ES350 2008 ML and i've just bought an used set of mag (ASA) for the winter tires, specs are 17x6.5, offet +38.
First of all, the wheel holes are too small for my OEM lug nuts. On the ASA wheels, the lug nut seat is acorn or conic. At first look, the wheel fit my car, but there is alot of play on the hub studs. My thinking was ok, it only need some acorn nuts and i'm fine, but now, i've learned there is more things to know about.
What goes on my OEM wheels are http://www.ezaccessory.com/Toyota_Le..._p/98-0003.htm
Now, what should i use on my ASA wheels ? and what should i know, security wise, do i need spacers, acorn nuts or bulge acorn nuts, which i know nothing about.
thank you very much.
Well assuming the wheel dimensions you listed are correct and the hub bore is equal to or larger than 60.10mm, the wheels will fit without spacers. What you'll need is SD 12x1.5" lug nuts and if the hub bore is larger than stock (60.10mm), you'll need hubcentric rings.
