Deep, permanent stains/etching on inside of rims due to dripping brake pad acid
Old 03-30-05, 11:33 PM
PERRYinLA
PERRYinLA's Avatar
Default Deep, permanent stains/etching on inside of rims from the chrome plating process
These stains look like they were left over from the harsh chemical used in the chroming process. Here are some pics to show you what I am talking about.
They all have a drip-like pattern, starting at the center of the wheel and then migrating towards the (lower) inner edge, which suggests gravity was at work, and resisted all removal attempts, including scotch-brite, steel wool, wire-brushing and sandpaper. I ended up having to resort to painting them to cover it up.
Old 04-02-05, 03:24 PM
TLW
TLW's Avatar
Was It The Chroming Or The Brake Fluid ???
Old 04-02-05, 05:54 PM
PERRYinLA
PERRYinLA's Avatar
The stains are on all 4 rims, and very stubborn to remove, so I ruled out brake fluid, which does ruin paint but otherwise is not a big deal on metal. Besides, what are the chances of all 4 calipers leaking brake fluid at some stage, and then, only once per wheel, when the car was stationary?
By the way the stains formed I thought that whatever it was, was likely to have dripped down from the caliper area, pooled onto the inner wheel, then flowed down onto the tire. But I posted the same pics on the detailing forum www.Autopia.org and one response I got was that it was from the chroming process, which makes sense.
domonas
RX - 3rd Gen (2010-2015)
12
04-22-18 09:15 AM
See5
Suspension and Brakes
12
07-12-13 12:21 PM
GS300 I6
GS - 1st Gen (1993-1997)
04-07-09 12:27 PM
tuan92129
03-17-09 07:02 PM
orangecar
09-22-07 11:18 AM
Quick Reply: Deep, permanent stains/etching on inside of rims due to dripping brake pad acid
