what is the proper foot pounds to tighten lugs on a gs300/400/430 using a torque wrench.
i did a search and someone mentioned 40 pounds initially and then 75 pounds to finish it off using a star pattern. I've also read in another post to use 92 foot pounds.
is this correct?
i don't want any wraped rotors from over tightening.
the proper tqr calvin is 76 foot pounds , do not go beyond 80lbs for you will risk warping rotors easily among other things such as damge to wheel bearing s ..
but for aftermarket, you might want to put a bit more, i do 85. coz' if you actually try, with the aftermarket wheels, most likely you have less turns before it tightens up
