Suspension Springs, shocks, coilovers, sways, braces, etc.
Rear Shock - AVS or Regular
Old Nov 23, 2022 | 07:14 PM
rahanna's Avatar
rahanna
6th Gear
Default Rear Shock - AVS or Regular
Hi everyone ...
I just purchased a 2013 Lexus GS 450h with 83K miles on it.
The car drives great except for an annoying noise in the rear which after checking in the trunk, I found the rubber on top of the shock mount cracked in pieces and there is some grease/oil in that area.
My mechanic friend recommended I go to the dealer provide the VIN and get a new shock and the absorber rubber cushion on top.
Based on my VIN, the dealer provided me with the following part numbers:
48530-80756 ... Shock Absorber (Rear Right)
90948-01101 ... Cushion
Based on my car VIN, the dealer confirmed that this is a regular shock.
There is a plug on top of the shock absorber that I am not sure of its function or if this is an Adaptive Variable Suspension shock.
Please check the attached picture and let me know your thoughts as I am clueless.
Thanks!
Rear Passenger Shock Mount area
Old Nov 23, 2022 | 07:24 PM
GrandSedanFan's Avatar
GrandSedanFan
That is an AVS shock.
Old Nov 23, 2022 | 07:42 PM
jgscott's Avatar
jgscott
That is what the top electrical connector is for the AVS control that adjust the Strut.
Old Nov 23, 2022 | 07:53 PM
rahanna's Avatar
rahanna
6th Gear
Thanks guys for the info ...
So the dealer quoted me the wrong shock ?
Is the AVS Shock totally different from the regular shock and has a different part number ?
Old Nov 24, 2022 | 07:07 PM
GrandSedanFan
Totally different with a different part number.
AVS shocks are adjustable, adapting to the road, drive mode, and your control inputs. A solenoid in that housing bolted to the top of the shock rotates a tab on top of the shock to adjust the damping.
Old Nov 24, 2022 | 09:04 PM
rahanna's Avatar
rahanna
6th Gear
Thanks @panyo64
Honestly the ride is perfectly fine, soft and very comfortable. It is only the cracked cushion on top of the shock that is causing the knocking/clunking sound and can be only heard in small bumps
Do you think I can change the top cushion only as it seems that the dealer does not have the AVS shock in stock ?
Old Nov 25, 2022 | 08:27 PM
jgscott's Avatar
jgscott
Is that Strut leaking? Have you had it checked? Where is the fluid coming from up top? If the strut is ok then you could just change the Strut mount.
glacier221
Feb 14, 2022 06:43 AM
maubster16
RC F (2015-present)
Nov 8, 2021 07:11 PM
ultran00b8
Jan 11, 2016 03:04 PM
fastryan
Suspension and Brakes
Jun 17, 2010 10:45 AM
ToyotaLexus
RX - 1st Gen (1999-2003)
Jan 31, 2009 11:17 AM
