questions for people with airrex
I just finished installing the airrex air suspension on my 3gs, but im having trouble understanding a couple things with the system, and hopefully some of the airrex owners can chime in.
1) Does it matter what MAX/MIN tank pressure I set the system to? Is it simply to adjust when the compressor turns on, or should I avoid keeping a high pressure in the tank? (the options are as follows (MIN/MAX psi): 120/160, 140/180, 170/205[default]) 2) Per corner, what is the maximum psi I can set the pressure to? Im especially concerned about what I should be setting my maximum height preset to. 3) I have airrex with the all-in-one box, and when leaving the toggle switch on the box to the "on" position after turning off the car, the motherboard? continues to be illuminated with various lights. Is this normal or should the system be fully off (i.e. no lights)? ...for what its worth, the compressor does not turn on when the car is off. 4) Prior to purchasing this kit, ive heard that you can adjust the air-out speed... where is this option? 5) Where is the "ride height on start" option? Sorry for the many questions. The kit obviously came with instructions, but seeing how im located in japan, it came with japanese instructions and does not include any of the info above. Thanks in advance! |
I run 175 in my tank...which is the max pressure my system goes to..the tank can handle 200 psi. I'm pretty sure the tank that comes with the airrex is rated for 200 psi as well. You need to play around with the pressures and see where you end up at fully aired out to fully aired up..it just depends on how much air it takes to fill your bags. If you don't 'play' around with airing up and airing down in a short time, the lowest preset would work. If you want more play time..you'd need a higher tank pressure otherwise you might not be able to fully air up until the tank refills.
I run UAS bags and don't air them up over 100 psi(speed bump preset)...your bags should say max pressure on them... The slow down valves are mechanical on the Airrex I believe..so you have to actually adjust the knob on the valves manually. Sorry I can't answer all of your questions but hopefully it's a start! |
I appreciate your help!
Im new to air, and i still have alot to learn.
Originally Posted by avs20
(Post 9215742)
How do i determine when the bags are "fully aired up"? Do i keep filling until the car doesnt go up any higher? |
I ended up contacting airrex directly, and just to help people out, here are the answers to my questions:
1) As explained by avs20, this is a personal preference thing 2) The struts will eventually reach at point where the car doesnt go up any higher. As for determining the pressure for the max height preset, as an example, if the car reaches full height at 100psi and any pressure beyond that is the same height, choose 100psi. 3) The system will turn off after 15min or so. Just make sure to manually turn off the remote if its not plugged into the usb cable. 4) As explained by avs20, a knob on the valves 5) There is no "ride height on start" option Apparently, everything is written in the manual (albeit not the japanese manual), so im assuming most people wont have the same concerns i was having :egads: |
Did they give you a max pressure that the bags are rated to?
(Post 9217567)
