Suspension Springs, shocks, coilovers, sways, braces, etc.
Tein CST asymmetrical rear settings ???
Old Jul 14, 2009 | 10:12 PM
I8ABMR's Avatar
I8ABMR
Default Tein CST asymmetrical rear settings ???
I was under the car today to check the rear tires and check out the F sport sway bars and noticed that there is a difference in the settings for the rear coilover assemblies. The right side is set a touch lower than the left. I remember the tech saying something about doing that to compensate for the weight of the driver. I also noticed that the tech left 2 threads from the bottom on the lower side when he set to the "bottom". I called the shop and the tech said its not good for the coilovers to be set to the very very bottom. I think he is just trying to avoid having to get under the car again and take care of it. I dont think its worth it to take it in to squeeze the last 2-3mm and have to realign. I was just wondering if you have heard the same stuff or is this guy BSing me??
Attached Thumbnails Tein CST asymmetrical rear settings ???-img_0046.jpg   Tein CST asymmetrical rear settings ???-img_0002.jpg
Old Jul 25, 2009 | 10:46 PM
I8ABMR's Avatar
I8ABMR
10 days with no reply .she looks great the way she is . Thanks for all of the help
Old Jul 27, 2009 | 08:15 AM
stvincent's Avatar
stvincent
i had a similar problem, but i don't think my info is valid since the adjustability of tein coilovers is different than mine..
where the peeps with the tein coilovers at? they should chime in.
Old Jul 29, 2009 | 06:38 PM
passnu2's Avatar
passnu2
I wouldn't believe it. Its its set up to go that LOW then they are MFG to handle it. If anything I am sure the lower you go on any coil would wear them faster then a higher setting. I may be 100% wrong but I think this guy is being lazy.
Timbo02
Suspension and Brakes
Aug 18, 2013 12:16 PM
BLkARIST0
19
Dec 11, 2008 09:42 AM
MELGS300
Aug 15, 2005 08:47 PM
MikeGS4PE
32
Feb 1, 2003 04:11 PM
MRGS400nSoCali
22
Apr 21, 2002 12:25 PM
