Thanks for that and is this for the up & down ? I have a problem as my lights are going up and down very fast I think it's a faulty sensor hope it's the same as the isf as its still under warranty so I will swap it then take it in to lexus
Just replaced my rear struts and got the flashing AFS light. Thanks to this great post I was able to fix it quickly. Instead of removing the 10mm nut from the sensor I loosened the nut on the stabilizer link and moved the leveling arm to the correct position as shown in the picture. After this adjustment the flashing AFS light went away. Great job smalldog and thanks for sharing!
Good to go. I hope this clear up a lot of confusion. All I did was remove the nut (10mm) from the sensor ( has the wire plugged to it) and turned the arm to ( L or 180 degrees) position. I had to remove my tire to get to it. 10min job.
Note:..It should be no need to adjust the adjustment bolt. Look at the first pic when I said " I moved it in every position and had no luck" on page 3.( I think everyone that couldn't fix it was moving the same part) Also note the elbow part in that pic is also in the up position. I got that pic from the IS side. Thanks guys
Thanks very much. Got the NF210's put in today and AFS is flashing; I'll have my shop make this adjustment as soon as my new rims & tires arrive.
Small thread revival here to say thanks! Noob just got my 08 lowered, AFS blinking, got it home jacked it up lost the tire, leveling arm adjusted and a quick joy ride (to get beer!) all of 30 minutes total and no more blinking!
