Suspension Springs, shocks, coilovers, sways, braces, etc.
USRS Install Question
Old Aug 31, 2025 | 10:34 AM
Nikonfan's Avatar
Nikonfan
Default USRS Install Question
I'm about to install my USRS bushings today. I emailed RR Racing, but I'd be surprised if I hear back from them over the holiday weekend.
I have a question about the torque specifications. The USRS instructions call for 150 ft/lbs for the 22mm bolt, and 110 ft/lbs for the spindle nut. However the TIS service manual calls for 111 ft/lbs for the 22mm bolt and 83 ft/lbs for the spindle nut. (see photos).
I don't want to over tighten and damage the bolts. Please advise.
Thanks,
Frank
Old Sep 21, 2025 | 01:38 PM
Nikonfan's Avatar
Nikonfan
If anyone is interested, this is how the conversation with RR Racing support went:
Hello,
I have a question about the torque specifications. Your instructions call for 150 ft/lbs for the 22mm bolt, and 110 ft/lbs for the spindle nut. However the TIS service manual calls for 111 ft/lbs for the 22mm bolt and 83 ft/lbs for the spindle nut. (see photos).
Thanks,
2013 GS 350 AWD (Base)
We prefer to use our figures (espeically on the axle nut) as they can come loose. You will not overtighten. Thank you
Okay, Thanks for the reply.
I ended up installing the bushings yesterday and I'm amazed and what a difference they make in the feel of the car! I did torque the bolts to the factory spec. Maybe I'll go ahead and tighten the spindle nut a bit more, I did put some lock tight blue on the threads as well. Is there something about the USRS bushings vs the stock that makes the nut more prone to coming loose? I also noticed that the factory service manual specifies 143 ft lbs for the 22mm bolt on the RWD GS, and 111 ft lbs on the AWD GS (mine) so I wonder if they have different bolts?
Thanks
Not sure about the different bolts. Glad to hear that they are working well for you. I wouldn't put too much into the torque. But I think adding a little more to the spindle nut is a good idea. Thank you
Old Sep 22, 2025 | 10:04 PM
amerrival's Avatar
amerrival
4th Gear
Default How??
I have a 2013 AWD F Sport, and I have tried 3 separate times to fit these LCA USRS (Street Version) bushings on my car. No matter what, the alignment of the inner hole that goes into the subframe assembly suspension crossmember does not line up at all. After removing the front bushing fastener, my brother and I were able to manipulate the RR bushing into place in the rear on the driver side and installed it the rest of the way. Even after all that the fitment was still terrible as there is a gap on the top between the brass thrust washer and bushing whilst the bottom is super tight, even with tightening the outer pre load fastener to close up the gap as much as we could. Just when you thought it couldn't get any worse... I went to install the passenger side, but didn't have the extra hands to manipulate the bushing to thread in that inner fastener, so I stripped out the hole pretty bad. I bought a Helicoil kit and when that came in I drilled the hole, but when I was tapping it upside down at an angle with less than a foot of maneuverability; I went in crooked and messed the hole up even worse. Not only that, but ironically for a guy that wears safety glasses everyday at work, I wasn't while working on this at home and got metal in my eye so that made everything else worse of course (Yes, I learned my lesson). Now I am without a car for days and the foreseeable future since nobody knows if they can repair the hole or they say they can't do it, or they say they would replace the whole frame which of course is way too expensive. My question to you is, how was lining everything up so easy for you? I've never had these sort of fitment issues with any aftermarket parts on any of the cars I've owned.
Old Sep 23, 2025 | 02:42 AM
Nikonfan's Avatar
Nikonfan
Wow! Sorry to hear you had so much trouble!
I had no problem with the holes lining up. I did have some trouble getting that bolt to thread back in. Rather than forcing it and damaging the threads, I used a thread chaser kit to clean up the threads on the bolt and in the hole, then in went back in without any issue.
I'd have to go and check, but if memory serves me correctly that bolt is a M11x1.25. Is there any reason you cant just drill out the stripped hole, then tap the threads to the next size up?
Old Sep 23, 2025 | 08:05 PM
amerrival's Avatar
amerrival
4th Gear
Geez, that's crazy that you even had to do that. But you were smart enough I suppose to stop and knew exactly what you had to use to correct the situation. I would have never thought of having to go to such lengths to modify my frame in order to fit what were supposed to be straight forward bolt on parts. I thought it was an M11x1.25 fastener as well, as it does say 11 on the head, but when using a thread tester at O'Rielly's we found that apparently it's an M12x1.25 fastener so I purchased and attempted to repair the hole with an M12x1.25 helicoil kit. I'm not sure how going oversize would work, since the bolt needs to be small enough to fit in the bushing housing hole (which is an oval shape) and probably needs extra room for the preload fastener to tighten it down as well. Not only that, but I'm sure the torque values would change with an oversize fastener so Idk what those values would be.
Old Sep 24, 2025 | 02:38 AM
Nikonfan's Avatar
Nikonfan
Originally Posted by amerrival;[url=tel:11970211
11970211[/url]]Geez, that's crazy that you even had to do that. But you were smart enough I suppose to stop and knew exactly what you had to use to correct the situation. I would have never thought of having to go to such lengths to modify my frame in order to fit what were supposed to be straight forward bolt on parts. I thought it was an M11x1.25 fastener as well, as it does say 11 on the head, but when using a thread tester at O'Rielly's we found that apparently it's an M12x1.25 fastener so I purchased and attempted to repair the hole with an M12x1.25 helicoil kit. I'm not sure how going oversize would work, since the bolt needs to be small enough to fit in the bushing housing hole (which is an oval shape) and probably needs extra room for the preload fastener to tighten it down as well. Not only that, but I'm sure the torque values would change with an oversize fastener so Idk what those values would be.
Yes, you're correct M12x1.25, I couldn't remember off hand.
Cleaning the threads had nothing to do with the USRS, I would have had to do that even if I was installing the oem bushing, I had a hard time starting the bolt even without the bushing in place.
The next standard size would be M14x1.5 (automotive grade 10.9 or higher). You would of course have to widen the oval hole of the USRS by 2mm to make it work. As far as torque specs, look here: https://www.metric-bolt-torque.com/m...-torque-table/ The preload shouldn't be an issue, we're only talking about an extra 1mm on that side of the bolt.
I cant think of any other reasonable course of action to resolve your issue. Maybe others here who are more knowledgeable than myself might have a better idea, or if you have a reputable shop you go to, see what they think? If you haven't already done so, reach out to RR Racing themselves. Their support team is very responsive and they might be able to help.
Amigo
NX - 2nd Gen (2022-current)
Aug 15, 2024 07:05 PM
ValSal
Suspension and Brakes
Jan 23, 2024 01:02 PM
StaticMatt
Sep 19, 2021 11:31 AM
shouldibuy
Mar 28, 2019 11:30 AM
smackrel
IS - 1st Gen (2001-2005)
May 15, 2001 08:58 PM
