3IS AWD pulls right under hard accel
Hey everyone, I got stiffer lca bushings installed that all forums said were compatible with this car and reduced the terrible front inner tire wear. I also got fresh dws 06+ tires on all 4 corners and an alignment. The car, a Lexus IS 350 AWD, has been pulling to the right under hard acceleration, and I'm not sure what's causing it.
I filmed a video to see if the bushings weren't torqued all the way because they used an impact instead of a torque wrench, but everything seems fine?
Tire pressures are always correct, alignment was performed and checked later when I noticed the issue. What could the problem be? Could there be torque steer on a rear biased AWD car?
