Proportioning Valve or T-Fitting?
Old 03-07-16, 06:50 PM
nguye569
nguye569's Avatar
Default Proportioning Valve or T-Fitting?
Can someone with more knowledge than me tell me if this is a brake proportioning valve or just a simple t-fitting? This is located in the rear of the car - 1 line is coming from the direction of the master cylinder and the other 2 lines go towards the rear brakes.
I went to AutoZone today to see if I can get this part to fix some corroded parts, and the person helping me says its a brake proportioning valve. I have been looking online for about an hour and can't find any parts matching for an SC300. Based on the level of corrosion for just the part and some of the lines right out of it, it looks to be a cheapo t-fitting that was put in by the previous owners years ago.
Attached Thumbnails Proportioning Valve or T-Fitting?-img_20160307_185009.jpg
Old 03-07-16, 08:16 PM
Seefo
Seefo's Avatar
There is no prop valve on the SC300. Its all done in the ABS module.
That is the block/T that splits out to the two calipers in the rear.
Edit: The PN is 9041310260.
Old 03-08-16, 05:36 AM
nguye569
nguye569's Avatar
thank you so much! things are so much easier when there's a part number!
I'm glad i came on here before having the guy order me a universal proportional valve
Old 03-08-16, 09:36 PM
INTIMAZY
INTIMAZY's Avatar
I hope you're changing out those brake lines in the process. Those look a lot like mine and mine rusted through and failed 2 years ago.
Oh and a generic T from the local auto parts store works fine and costs just a few dollars.
Old 03-09-16, 05:45 AM
nguye569
nguye569's Avatar
Yes I do plan on changing out the brake lines. How were you able to run a new line from the master cylinder to the rear? Or did you just cut and make a new flare from the end after replacing the T?
e60bmw
08-05-16 09:02 PM
RedPhoenix
Suspension and Brakes
11-21-09 01:02 PM
Djdot2k
07-12-07 09:31 AM
Lexs400
01-16-03 05:04 PM
Quick Reply: Proportioning Valve or T-Fitting?
