Front brake change question..
Old 06-25-14, 12:31 PM
Ants350
Ants350's Avatar
Originally Posted by aw04lfan
Yup, the akebono brake shims have nitrile rubber on both sides, and it's a single shim solution that works very well (my brakes are smooth and quiet). Other aftermarket pads do not come with quality shims. In that case I would use the 2 OEM shims if they fit, but I would not triple shim (aftermarket + 2 oem shims) Video Link: http://youtu.be/WsaEtMaW6Qw.
so with the aftermarket pads that have shim built on there's no need to put anti squeal lube on shims than?
Old 06-25-14, 02:31 PM
Noeh
Noeh's Avatar
Always use a quality silicone-based brake lube, makes a big difference.
Old 06-27-14, 12:49 PM
Ants350
Ants350's Avatar
just cleaned and lubed em up good no more squeaks for now!
Old 06-27-14, 07:28 PM
Noeh
Noeh's Avatar
10 char
ac921ol
07-24-12 11:05 AM
I8ABMR
12-30-09 09:14 PM
Jeepdude
04-21-09 06:26 AM
wjimmy
Suspension and Brakes
10-06-08 02:46 PM
95SC400
SC- 1st Gen (1992-2000)
10-25-02 01:30 AM
Quick Reply: Front brake change question..
