Coilover Users...Height problems? (TEIN FLEX)
i got a list of " i can live with that" on my ride also. by the way, good choice keepin the foglights yellow, looks real sweet with the blue. good stuff!
wanna make it hid yellow fogs thoughbut yeah, i figured i should care about my car, but not pick on every single thing
i have come to the conclusion that this is normal. and by all means please don't adjust your coilovers to different height left and right. you should ALWAYS have the same number of coils setup left and right, otherwise, it's bad for the suspension.
Have you ever heard of corner-weighting?
The coils should be adjusted by weight on each tire so that it is even...not height.
R
Are you sure?
R
Are you sure?
R
Mike:
Thank you for your interest in TEIN High Performance Suspension Products.
In regards to your question, you can adjust the length of the shock to
compensate for the height difference but is better to actually corner
balance it. And by adjusting the length of the shock, it would not effect
the stroke of the suspension.
Staff @ TEIN USA INC.
7631 Somerset Blvd.
Paramount, CA 90723
Phone: (562)633-7387
Fax: (562)633-7291
www.tein.com
That's a relief for me
TIME TO SLAM IT!!!
ATTENTION TEIN FLEX USERS...I just received a response from tein...
Mike:
7631 Somerset Blvd.
Paramount, CA 90723
Fax: (562)633-7291
www.tein.com
TIME TO SLAM IT!!!
NOOOO...only if you can adjust the shock tube lenght!
The HAs do not have that adjustment.
Then, if the height is uneven, you can adjust the shock tube length as this will not affect corner weighting. (only certain coils)
R
First you corner weight...you CANNOT have ideal handling without doing this.
R
Anyone that actually knows suspension for sure out here?
R
I'll email my race freind...
Lowering the shock tube, according to what these guys say, does affect the weight at that corner...I think that's how you get the perfect combination...basically...LF+RR=RF+LR (lbs or kg)
...of course, real racer shops take into account the driver and fuel...Although not ideal, I am going to simply adjust the shock tube length, but will try to find a race shop that can corner weight my car...In order to get the perfect balance, I am sure it would take a few weeks
As far as measuring your heights, I'm wondering if any of you measured your car's before you did the mod. The chassis may have already been slightly tweeked. Unless this is known, I think the jury is still out on whether the Teins are responsible for introducing this problem.
Also flat surfaces can be deceiving, so you should verify your measurements by taking your car to 3 or 4 different spots and re-measuring. Not that I don't trust your measurements, but you might be surprised at what you may find out if you do this.
After all this, I would measure the thread spacing of all 4 coilovers to make sure the settings are exactly the same, left to right.
Verifying these things will help narrow down what the root cause of the problem is. Right now, we've got too many variables, to make any accurate conclusions.
