EBC ceramic pads
For all GS and IS models up to 2013, looks like the front is DP31589C and rear is DP31586C EXCEPT for the 2013 GS 350 that uses DP31850C.
I would imagine front pad replacements would still be the same and prior GS and IS pad replacement. Or would it be different? Also what of the rear, up to 2013 GS350 it seemed all IS350 and GS 350 were on the DP31586C model, would the 3IS be using the newer DP31850C?
"I do see that the part numbers were the same between the two up to 2013 with the difference of the rear pads. Unfortunately I can’t verify any fitment for the 2014 IS350 yet. We do not have any information yet from our R&D department. I did call our local Lexus dealer parts department and they did verify that the part numbers from the 2013 IS350 are different from the 2014 IS350, and as of now our catalogs do not have part numbers listed for the 2014 IS350. It shows up to 2013. I’m hoping by mid 2014 I will have some information available for your IS350. I’ll follow up with you then to give you an update. In the mean time if you go on our website, we have e-catalogs that are updated periodically you can check through, page 296. Hope this gives some insight for you, please let me know if you have any other questions!"
