Flush Spacers on Fsport Rims
Old 04-06-17, 10:36 AM
  #211
Sheddy
Sheddy's Avatar
Originally Posted by gbgary
looks like they clear. nice.
Yes if you are stock height its fine. If you are lowered 25mm F and 20mm R for a flush setup.
Old 04-06-17, 10:54 AM
  #212
Jbreezie
Jbreezie's Avatar
Did you have to shorten the stock studs?
Originally Posted by redline.gT
Currently running 20mm up front and 15mm rear
Old 04-06-17, 10:56 AM
  #213
Jbreezie
Jbreezie's Avatar
"Not available in CA" 🙁🙁
QUOTE=Sheddy;9827007]http://www.burgertuning.com/lexus_wheel_spacers.html
Well made 25mm spacers for $36 a pair![/QUOTE]
Old 04-06-17, 11:44 AM
  #214
Sheddy
Sheddy's Avatar
Originally Posted by Jbreezie
Ahh sorry Californians.
Old 05-05-17, 09:03 PM
  #215
srv777
srv777's Avatar
If you are using 15mm in the back, the stock studs need to be shortened as they hit bottom out on the back of the open holes on the wheel. 30 seconds on each stud with the grinder fixed that problem!
Old 05-06-17, 08:19 AM
  #216
gregerst
gregerst's Avatar
I am thinking about trying a 17mm for the rear. Do you think it would clear the studs?
Old 05-06-17, 11:33 AM
  #217
srv777
srv777's Avatar
Based on how much I grinded off, I would estimate that 17mm would work. Interesting to hear that others have reported rubbing using 20mm spacers. Looking at how close the tires are to the fender using 15mm spacers, it is really close. Also, interestingly, the drivers side has less space than the passenger side on my car.
Old 05-19-17, 08:11 AM
  #218
rizzagt22
rizzagt22's Avatar
I went ahead based on recommendations via this thread and installed a 25/20 setup front and rear respectively. I drive an IS250 lowered on RSR Downs. Visually it looked great and flush, however the the constant rubbing when going over bumps or dips bothered me and I don't want to cause damage to the fender liner or fenders.
The shop mechanic mentioned that since I running an all season tire with more tread, that can also cause the rubbing.
Anyone with a 20F and 15R setup with RSR Downs?
Thoughts?
Old 05-19-17, 08:43 AM
  #219
Sheddy
Sheddy's Avatar
Thoughts?
Can you send a picture of your tire and fender clearance? I am running 25 F 20 R with Bridgestone Potenza RE760 sport tires and i rub slightly on dips.
Old 05-19-17, 10:54 AM
  #220
rizzagt22
rizzagt22's Avatar
I took the spacers off already, but since the Bridgestone's are a lower profile tire with lower tread rating, you should have more clearance and less frequent rubbing.
Old 05-19-17, 05:58 PM
  #221
srv777
srv777's Avatar
I have this setup and there is no rubbing. As mentioned earlier one side is closer to the fender than the other.
Thoughts?
Old 05-19-17, 06:11 PM
  #222
rizzagt22
rizzagt22's Avatar
You have the 20/15 setup? Can you supply pics?
Old 05-24-17, 02:38 PM
  #223
srv777
srv777's Avatar
20/15 mm spacers:
https://goo.gl/photos/QVBxpPNrj7vG8VZG7
https://goo.gl/photos/4AZRWMt2zRKBaUmw6
Old 05-24-17, 03:45 PM
  #224
Cthan3o3
Cthan3o3's Avatar
what brand do you have and did you have to shave the studs?
Old 05-24-17, 04:21 PM
  #225
srv777
srv777's Avatar
Used Ichiba version II for front and B2B Design for the rears.
Yes I had to shave the studs by a few mm in the rear.
Quick Reply: Flush Spacers on Fsport Rims
