Sway bar kit
Old 03-10-15, 10:43 AM
  #181
Ahheck01
Ahheck01's Avatar
Okay, I bought them from here for slightly less, also better feedback:
http://www.ebay.com/itm/321688626225
Old 03-10-15, 10:51 AM
  #182
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
looking forward to your review...
Old 03-10-15, 11:16 AM
  #183
Ahheck01
Ahheck01's Avatar
Will do. Current suspension:
Factory shocks with 140k
Tanabe NF210 Springs
Factory sways
Factory rear sway bushings
Poly front sway bushings
Planning on installing poly rear sway bushings along with the new bars.
The car needs shocks, and I have some Bilstein HD's to put on, but collecting new shock mounts etc., and need to find a great deal on new front upper control arms - probably SPC to correct my minor caster issue and get camber back into spec. Planning to do all that when I put summer wheels/tires back on in a month or so.
Old 03-10-15, 12:51 PM
  #184
tmf2004
tmf2004's Avatar
Unfortunately the TRD bar comes with rubber sway bushings but i ordered some MOOG poly 31mm to use when these wear out for under $20 on Amazon. Its going to be night and day difference when everything is buttoned up and installed...
Old 03-11-15, 10:41 PM
  #185
Fromthesha
Fromthesha's Avatar
Hotchkis are a solid brand
Old 03-12-15, 04:46 AM
  #186
tmf2004
tmf2004's Avatar
indeed but they don't offer sways for the GS
Old 03-21-15, 02:35 PM
  #187
hcharlesc3
hcharlesc3's Avatar
Just ordered a set of these. I'll also write a review
Old 03-21-15, 05:16 PM
  #188
marshun
marshun's Avatar
so...to the other guys...sup with that review? hehe.
Old 03-21-15, 05:17 PM
  #189
Ahheck01
Ahheck01's Avatar
Just haven't had a chance to install yet. Hopefully Mon-Tues.
That said, I still have worn out factory shocks with my NF210's, so I don't know that my review will necessarily be the most relevant.
I will be using poly bushings, modified for the new diameters.
Old 03-28-15, 12:06 PM
  #190
Ahheck01
Ahheck01's Avatar
Okay, I've had them on for 4 days now.
DIsclaimer, my current setup is:
  • 17x8 wheels with 225 front and 245 rear crappy snow tires with on road feel or lateral support.
  • Tanabe NF210 springs on original shocks with 140k mi that are on their way out.
  • Poly bushings that were made for stock bars, that had to be drilled out a bit to make space for the new ones.
That being said, I am pleased with the result. If you've gone from stock sway bushings to poly bushings on factory bars, I would say adding these bars makes about equal difference. I was expecting a bit more, but I think for a daily driver, it's probably perfect. Even with my horrible snow tires I have much greater confidence accelerating into turns. I think you would want a more aggressive setup for autox or anything like that, but then again you'd probably want a lighter car for that too, right?
If you have any questions let me know. All in all, I'm very satisfied. And they're red. Because racecar.
Old 03-28-15, 12:57 PM
  #191
RamAirRckt
RamAirRckt's Avatar
Mine the rear was black and front red. Are yours both red?
I wish the rear was 2-3 mm thicker. It just needs to be stiffer if you ask me!
As Herb Adams said "Ive never see too big of a sway bar"
Old 03-28-15, 01:38 PM
  #192
tmf2004
tmf2004's Avatar
i went to install my FIGS rear bar 2 days ago and turns out they sent the wrong bushings. So my car is on jacks until Monday....A little upset but what are you going to do... ***** happens....
@Ahheck glad everything worked out and they made a difference.... The rear fit ok.. any fitment issues?
Old 03-28-15, 09:59 PM
  #193
Ahheck01
Ahheck01's Avatar
The only fitment issues were the bushings, which were made for stock bars. We modified them, but not enough, so they were stretched, and the brackets are stretched a bit. Solid enough to work, but when we put the coils on in the next week or three, we'll see if they're still tight/secure.
Old 03-29-15, 04:54 PM
  #194
marshun
marshun's Avatar
cool. thanks for the review!
Old 03-29-15, 05:32 PM
  #195
Measured
Measured's Avatar
@Ahheck01 - would you say it was worth the purchase? I have poly bushings and always wanted a little more turn in. The bushings alone did a fair job for what it's worth, but I still want something more aggressive, even for a DD.
Quick Reply: Sway bar kit
