At what drop do you start needing camber kits?
TM engineering can get them, but they'll take forever to get them to you. There's 100's of threads on the highway shimmy, but I'll condense that for you, especially since you're a fellow new englander and you should get back to watching the B's
-ball joints
-tie rod ends (inner and outer)
-steering rack bushings to poly (Big culprit here)
-control arm bushings to poly (or arms themselves if they've had it)
-tires balanced, check wheels for any bends
-4 wheel alignment
if you do all that and it's still there, I'd have doubts about the straightness of your front subframe.
-ball joints
-4 wheel alignment
So far this is what I've priced out from Sewell using the CL discount.
Lower Ball Joint : $125.24 Set
433403941502
http://lexus.sewellparts.com/accesso...2002/2950.html
Outter Tie Rod Set: $97.50
454605901502
http://lexus.sewellparts.com/accesso...2002/2883.html
No listing for the inner tie rod? Is that the same as the lower caster arm #2? If I can just get the bushing from Sewell Lexus.
Caster arm bushing: $67.94
537SET
http://lexus.sewellparts.com/accesso...2002/4685.html
These items I'm still trying to source pricing.
as for balance, I just had my 19s road force balanced and I'll get the 4 wheel alignment after these items have been replaced.
Thanks Brotha!!! Go BRUINS!
433403941502
454605901502
537SET
433403941502
454605901502
537SET
did a quick search on sewell and look!
Bushing: Steering Rack: $31.56
Part# 207
http://lexus.sewellparts.com/accesso...2002/4558.html
wackedgs3
May 20, 2013 09:26 AM
S2dannyKeo
Apr 4, 2012 05:36 AM
