Slammed AWD ISx50s and CV Boot
#46
So when you start feeling vibrations does that mean that it's tearing up your cv boot as it vibrates which means raise it back up to the height where it won't vibrate? OR It's normal when it vibrates and just deal with as all lowered cars are known to have cv boots go out?
#48
The vibration isn't as bad as it seems. I first was scared to lower this car because of that issue but once I finally did I realized how minimal this issue is. I'm lowered on h&r.
#50
I lowered my car 24.5 inches from ground to fender and noticed the vibration / wobble then raised it back up to 25 inches from ground to fender which the majority says that it's the safe zone. However, it still vibrates and wobbles. I honestly don't even think it matters. Just lower your car. On any lowered car, the cv boot will eventually good bad. I plan on lowering it more.
#52
Post some pictures! I want to see it.
I think I am going to lower her to 24.5 inches all around this weekend! I am at 25 and still wobbles/vibrates. Might as well max out the coils.
#55
Heres a picture of my car currently at about 24 inches ground to fender all around if you guys were curious. Same vibration / wobble as when it was at 25 inches. Made no difference.
#59
I was on 19" and BC coilovers with two finger gap all around. Camber adjust is max out .At that time there is no SPC camber adjustment or Megan UCA.
Cons: CV boot leak.
Tire wear are more then it used to.
Break wear are more then it used to.
Vibration at start up.
Pros: Car look amazing.
Driving feeling is beyond amazing.
Top of it Project DONE.
Cons: CV boot leak.
