IS250 AWD - After lowering springs
i just had mine lowered on road magnets 2 weeks ago, with no shakes at all. i did an alignment right after lowering, and i think you need to do it asap. i got one more coming up after 1k km.
on alignment right after lowering:
i don't know if it's your wheel alignment that's causing the shakes, but just get it done.
I've had RM springs on my AWD for over 30k and no issues. I had a slight shake at one point and it turned out to be a wheel out of balance. Make sure your tires are good. and the alignment is correct.
BTW, I love the way the car feels on these. It made it just right. They did take a few months to really settle in.
I have owned and drove on RM's and loved it for what it was. Way better than stock.
Some AWD owners experience vibrations when changing from stock springs however. The guy I bought my BCR coils from had vibrations on Springs and Coils. I have his exact coils and no issues. I have a 06 with a 12/05 build date for reference.
your thinking in RWD terms... AWD is about 1 inch higher than the stock RWD so his 2 inch drop is the same as a 1 inch drop on a RWD.
Maybe i should take a pictures when i do the measurement. So you guys can give some suggestions. If i can get the springs instead of coils that would be great, cuz for coils i will need to save a little bit first
yeah, i owned the springs "shuturmout" just installed and had no problems. I dont know what kind of a gap you can expect on 18's but I had 20's and minimal to no gap. I will look for some pics later tonight if I can find them.
Coils are sick though because you can adjust the height anytime you want and dampening as well.
You should still go with the coils for better performance. Just keep an eye out for a used set.
20's with no gap any rubbing issue?
I have the same problem. I lowered the car on BC coilovers and I have also done 3 aligmment and wheel balancing, still had the problem 20mph+ then the shaking goes away. I have had it dropped for about a year or so I have had to change my CV boots. Other ppl on the forums had this problem aswell.
check the wheels they secured on?
i kno when i put my eibacks on i didnt have a problem when i had my volks on but when i put my stock wheels back on i had slight vibrations till i got all the wheels rebalanced, that could be it.
they say get an alignement when changing ride height or wheels from what i hear
