Megan Toe control arm (IS300)
I did replace mine also with TOP SPEED ADJ TOE ARM from a IS300, and like Mr Jokster said i does feel tight.
Here's the before with (coil overs, SAGE RCA front, SAGE RCA back on the +2 camber (middle) setting.
Here's the after with (coil overs, SAGE RCA front, SAGE RCA back on the +3 camber setting, TOP SPEED adj. toe arms.
DASHOCKER was the first one i think who fitted this adj toe arms
https://www.clublexus.com/forums/gs-...ictures-5.html
I will also have a set of toe arms for you guys in a month or so featuring higher grade components. Teflon lined ball joints and chromoly tapered studs. The Megans have a weaknes in that the sperical bearing is mounted in a tubular carrier that is then welded to a stud. I have seen this part break at the weld.
here is a rendering of my stud. It will be heatreated 4140 with rolled threads for strength.
Oh and I can also make trac rods for you gus as well. Here they are for the IS300
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Yeah, interested in the pricing of both? (hopefully not to much more than the Megan, fingers crossed)
The IS uses the same suspension components in the rear as the GS so what would be different about the trac. rods?
Kinda off topic but how long would it take you to make the control arm and trac. rod once an order is put in?
I will have two different tiers depending on the rod ends used. Pricing for Trac rods is already available at my site www.figsengineering.com Figure $140-$200 a set.
Also, the rear components are not the same as the LCA is longer. So I am going to say that the Trac link is also longer. The Toe link may work, but could be slightly shorter in its nominal length. Be careful about over extending the threads, the rule of thumb is 1.5X the diameter for minumum engagement.
I am currently in the process of ordering more sheetmetal parts to build LCA's and they will be ready in 4 weeks. Typical build time is 1 week if no powdercoating is required, 2 weeks if PC.
Fig
Fig
__________________
LexusK
Jul 16, 2018 08:28 AM
LexusK
sbullard33
Suspension and Brakes
Dec 10, 2007 03:50 PM
